Ford Lettering
Old Mar 11, 2013 | 11:47 AM
riggerparish's Avatar
riggerparish
Ford Lettering
Morning all,
Another grille related post.
I have noticed that on the 1963 F-100's, the FORD lettering above the grille was located directly below two of the four openings. However, on the 1964 version it had spread out beneath all four.
I am asking because I am a stickler for originality and I am desperate to find out if the front of my truck is original.
It is a 1963 but resembles the lower image (including the lettering). I would have thought that if the grille was simply replaced that it would have the spacing of the letters on the above image and the grille of the lower one.
So, does anyone know if any F-100's left the factory in 1963 resembling the lower image? I have both grilles just not confident enough to commit to one yet.
Really hope this makes sense
Thanks, guys!
Old Mar 11, 2013 | 12:35 PM
gangstakr's Avatar
gangstakr
Post your VIN number. That way it can be deciphered as to when it was built. Late production probably like the 64 Just a guess on my part.
Old Mar 11, 2013 | 12:44 PM
camperspecial65's Avatar
camperspecial65
Hmmmm, another interesting annomoly..I have a 64 upper valance...letters spead out like the pic...Ive got letters as well...Assuming the lower pic is your truck...you are missing the hood badge..
- cs65
Old Mar 11, 2013 | 10:55 PM
riggerparish
Thanks for the replies. The VIN number is:
F10CR360417
Does this provide any indication of when it was made?
Old Mar 12, 2013 | 07:17 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by riggerparish
Thanks for the replies. The VIN number is: F10CR360417
F10 = F100 2WD
C = 292 2V
R = San Jose CA Assembly Plant.
360417 = 1963, assembled December 1962.
1962/64's use the same letters, but 1964's are spaced further apart than 1962/63.
So why does your '63 have wide spaced letters? Truck involved in an accident, upper grille panel damaged, replaced by 1964 junkyard parts.
Old Mar 12, 2013 | 09:48 AM
riggerparish
F10 = F100 2WD
C = 292 2V
Thanks, ND. It appears so. An easy fix.
ttpenman
Jul 25, 2018 12:10 PM
crisman
Mar 2, 2018 10:04 PM
jpchiro
May 26, 2015 09:51 AM
redbeard_trucks
Apr 20, 2010 09:17 PM
silvercup_3
Jul 15, 2007 05:39 PM
