Whats This ??
Old Mar 6, 2013 | 12:07 PM
JMP E350's Avatar
JMP E350
Whats This ??
Hmmm Photo by namesmud | Photobucket
oh and where does it go ?
Also .. I found the plug to my AC compressor unplugged... any reason someone would unplug this ?
Its a used truck obviously... previous owner unplugged
Old Mar 6, 2013 | 12:25 PM
grec-o-face's Avatar
grec-o-face
It's an "intake air temperature sensor". It's normally inserted around the air filter assembly. I'd guess your truck has an aftermarket air filter installed. Some people will re-install it with the aftermarket filter. I wouldn't worry too much about it. But if you can, keep it close to the filter...
Old Mar 6, 2013 | 12:33 PM
allhuntalltime's Avatar
allhuntalltime
What grec-o-face said on the intake air temp sensor.
The a/c could be unpluged because of a bad compessor if it comes on and locks up
the belt could burn off and cause other problems.
Old Mar 6, 2013 | 12:34 PM
JMP E350's Avatar
JMP E350
ok Thanks!
Old Mar 6, 2013 | 01:18 PM
HH60FE's Avatar
HH60FE
Is the engine operational? Looks like the CPS is just sitting there, not plugged in. Hmmm
Old Mar 6, 2013 | 02:24 PM
BigAlsPSD's Avatar
BigAlsPSD
In the pic posted, are you referring to the plug out of focus behind the IAT? If so that is likely the connector for the EBPS.
Old Mar 6, 2013 | 05:27 PM
JMP E350's Avatar
JMP E350
Yup EBPS.. might as well plug that back in !
Old Mar 6, 2013 | 05:33 PM
HH60FE's Avatar
HH60FE
Ah, very good. I am mistaken. Thought the wiring couldn't reach that far up but it sure looks like a CPS.
Old Mar 9, 2013 | 12:38 PM
h2guy's Avatar
h2guy
Guys, thats the outside air temp sensor, mounted on the drivers side of the radiator, that shows temp in the overhead display. Inlet air temp sensor in the air filter is a clear plastic thingy with the yellow indicator inside.
Old Mar 9, 2013 | 12:46 PM
trekbasso's Avatar
trekbasso
Pretty sure it's the air filter temp, like has been mentioned. Your describing the filter minder, nothing to do with temp., just restriction.
Old Mar 9, 2013 | 12:53 PM
h2guy's Avatar
h2guy
Trekbasso, you're correct, my bad. I WAS thinking of the filter minder.
But the pictured item IS mounted as I described and not "inserted around the air filter assembly"
And I'm pretty sure it is what drives the temp display on the overhead.
xc4jokestomper
May 2, 2011 07:26 AM
drbalazo
17
Oct 13, 2006 04:16 PM
bradplock
1978 - 1996 Big Bronco
18
Sep 7, 2006 12:43 PM
otpracer100
Jan 24, 2006 09:52 PM
matt0588
May 21, 2005 05:53 PM
