Thanks Greg, Just working on tracking down a slow cranking problem, Batteries are only about 7,8 months old, I'm thinking it time to pull the starter and have it bench tested. 180,000 and the original starter.
I have heard that 14.4 is somehow optimum output from an alternator.
I too have something going on....2.5 year old Motorcraft batteries were dead this morning....charging them now then going to auto electric place to have them AND alternator checked.
You can try some voltage drop testing and see is your cables are the problem. Are you familiar with that process?
Check out the videos on this site. Some of these might apply to your issue. I had to watch them a few times and then try some testing on my trucks. I was able to expose a few issues that were easy to correct. Now I feel my electrical systems are in better shape than before.
I've had 3 sets swell on me in about 2-3 years. Alternator almighty with another set of battery's coming sometime.... The truck is sitting dead right now...
How many volts are to many volts? Running between 14.3 to 14.4 at around 2000 rpm.
Thanks,
Richard
12VDC is minimum. If you are getting 12V, you are charging the batteries OR running the vehicle, not both.
The ideal voltage for vehicles (of any size) to run the vehicle and charge the batteries is 14.4VDC. This voltage comes through the rectifier, since the alternator produces 3 phase AC voltage.
The alternator produces wattage based on demand, not as a constant. Low demand, less wattage is produced.
Batteries are what is used to get the vehicle started. Once the vehicle is started, the vehicle runs from the alternator. While running, the batteries are only used as part of the circuit and backfill for a short term under voltage situation. Otherwise, they are just charging in circuit.
Based on the 14.3VDC reading, check the batteries.
Well got a Chance to look into the slow crank issue some more today and found the problem. it's time to do something about the cable ends. the cable end on the drivers side was not making good connection and was a little corroded under the connection. All is good now and thanks for all the advice.
