What is this sensor?
Old May 18, 2005 | 07:16 AM
matt0588's Avatar
matt0588
Question What is this sensor?
I removed my air filter box to put in a napa 6637 air filter and there was this little sensor thing in the side of the air box, what is it for? I just set it under the new air filter. Should I put it somewhere else? Thanks for you help and for the help yesterday.
Old May 18, 2005 | 07:47 AM
Kwikkordead's Avatar
Kwikkordead
Ambient air temperature sensor, I think. Somebody who works on these trucks for a living please correct me here if I'm wrong, I am guessing that the Intake Air Temperature sensor is the one mounted in the Y-pipe next to the wastegate control valve.
Old May 18, 2005 | 09:18 AM
doc526's Avatar
doc526
You are right Kiwk. That is the ambient air temp thermocouple. Im not sure about the sensor in the Y pipe though.
When I did the upgrade to the Ford AIS kit, I took the old thermocouple out of the old housing to keep as a spare for the AIS. Twist it 90 degrees and it pops out of the housing.
Old May 18, 2005 | 09:33 AM
Steve_250's Avatar
Steve_250
Just tie-wrap the thermocoupler up so it gets the free air. If you are getting the NAPA filter you can (if you want to) take the filter minder and put it in the top of the NAPA. Just drill a hole in the plastic top, CLEAN OUT THE DEBRIS and pop the minder in.
Old May 18, 2005 | 06:35 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You mean the one that's threaded in to the Y-manifold? That's the intake air heater.
Old May 18, 2005 | 10:00 PM
Kwikkordead
You can see my sawed off Intake air heater in the upper left corner of the picture. The one that I am speaking of is the one down in the lower right mounted right next to the MAP signal tube.
Old May 19, 2005 | 06:36 AM
matt0588's Avatar
matt0588
Thanks for the help.
Old May 20, 2005 | 08:33 AM
Kwikkordead
Bump.
Now I am curious as to what this sensor is. Anyone know?
Old May 20, 2005 | 12:56 PM
Dockboy's Avatar
Dockboy
Bump.
It's the IAT (Intake Air Temp) sensor
Old May 20, 2005 | 02:06 PM
Kwikkordead
That's what I thought, thanks.
Old May 21, 2005 | 05:26 PM
cookie88's Avatar
cookie88
FTE Emeritus
I know it's semantics, but just for accurate terminology.
The IAT (intake air temp) sensor is the one plugged in to the intake box. The one pictured is the MAT (manifold air temp) sensor.
Old May 21, 2005 | 05:53 PM
Kwikkordead
Excellent.
towsrus
Dec 1, 2010 10:57 AM
firefighter0205
Aug 11, 2007 02:55 PM
matt21418
Jul 24, 2006 02:34 PM
otpracer100
Jan 24, 2006 09:52 PM
TexasGuy001
Feb 5, 2002 06:58 AM
