rustoleum orange peel question.
Old Mar 5, 2013 | 01:04 PM
Jimmyrig's Avatar
Jimmyrig
So I am going to paint my truck with the rustoleum sunrise red gloss. I have been pleased with my other rustoleum adventures so I thought I would give it a shot. I've been reading and see some varying opinions about sanding down the orange peel. Basically my question is should I wet sand it after every coat or just wait till after my final coat dries then wet sand / polish? I know to tack and wipe between coats.
Old Mar 5, 2013 | 01:14 PM
HIO Silver's Avatar
HIO Silver
If the orange peel is heavy, I'd wet sand it to correct it before shooting additional coats. ...Then correct the paint gun settings or technique used to apply the color.
Old Mar 5, 2013 | 01:16 PM
bucks77ford's Avatar
bucks77ford
I've read this thread a few times and it sounds like alot of work, but that's really all that is involved is work and it's cheap. I don't know if it's the right way or overkill in steps, but the final product from pics look great. The only thing I could see with sanding between coats is not to get things "too smooth" before the next coat or the paint will not stick. Of course the below thread is for roll on.
My "rustoleum $50 roll-on paint job"
Old Mar 5, 2013 | 01:27 PM
HIO Silver's Avatar
HIO Silver
The killer with Rustoleum jobs is long drying times. The more time the paint is open the more chances of getting dirt/debris/bugs on the finish.
Roll-on jobs requires around eight coats until full coverage.. with LOTS of sanding in between every couple of coats.
Patience is a virtue but it is super lo-buck.
Old Mar 5, 2013 | 01:36 PM
bucks77ford
The good thing about roll on jobs though is if it can be done in a garage or even a home made plastic enclosed area, not having to spray helps eliminate dust debris and if the floor is wet down prior, than that would further eliminate dust particles. Doesn't take care of the bug problem though.
What I find odd, is that rustoleum gets a bad rap, but how many times have we used rustoleum primer and paint from rattle cans on different metals and the stuff seems to stay on with no real great prep. Hell, today's actual automotive paint seems to need all this prep work to even stick. It must be all the EPA regulations and paint has become basically water.
Old Mar 5, 2013 | 05:20 PM
Twistbeard's Avatar
Twistbeard
I sand every two coats. Works great high gloss shine. 6 - 8 coats (roll on) before finished.
Old Mar 5, 2013 | 08:44 PM
teds74ford's Avatar
teds74ford
I basically scuffed between coats and then wetsanded the top coat
Yes, it's rustoleum but I sprayed it.
hound dog
Paint & Bodywork
Dec 17, 2011 04:39 PM
rmalottwtes30
Paint & Bodywork
Jul 4, 2007 02:33 PM
pwrstrokef350
Paint & Bodywork
Mar 14, 2007 09:55 PM
mk84bronco
Paint & Bodywork
Jan 29, 2004 02:21 PM
popman
Paint & Bodywork
Sep 27, 2003 05:01 PM
