AIS Filter Conversion
Old Mar 6, 2013 | 09:04 PM
  #31
MiamiPSD's Avatar
MiamiPSD
Originally Posted by Tugly
Mine looked so cheesy that I was too embarrassed grab the camera. "I'll just say it came this way if anybody looks."
Let's see it.......
Old Mar 6, 2013 | 09:28 PM
  #32
trekbasso's Avatar
trekbasso
Originally Posted by flavo
I actually lolled. Man up and take a picture for us less adventurous souls. It will make us feel better.
I'll try to save you Tug, is the sleeve really needed? I mean, it's nice to direct the air but if the filter is pulling that hard the hole will allow air to go in, right? The critical part is the hole in the side of the air box.
Old Mar 6, 2013 | 09:44 PM
  #33
MiamiPSD's Avatar
MiamiPSD
Good point......do we need a sleeve?
Old Mar 6, 2013 | 10:39 PM
  #34
MiamiPSD's Avatar
MiamiPSD
Check out the Volant #19873 set up. I wanta Fab a sleeve somewhat like the Volant has....
Old Mar 6, 2013 | 10:50 PM
  #35
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Probably don't need the sleeve. I'll take pics tomorrow for you. A hard plastic tube would be better to ensure air is coming from the wheel well. In the end, you could drill 20-30 little 5/64 holes in the housing there by the V-10 fender inlet and get the same result. That is what I should have done.
Old Mar 7, 2013 | 12:58 PM
  #36
Tugly's Avatar
Tugly
That's like saying "Go ahead and throw your choanies on the clothesline, we won't make fun of the racing stripes".
This is a proper device, you can see it's easy to fabricate from almost anything: [LINK]
Old Mar 7, 2013 | 02:12 PM
  #37
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
I got you, Rich. Here are some photos of what I did with the fender opening intended for the 6.8L engines. The foam sleeve is wedged between the inside of the fender well and the AIS housing. It can't move. You just need to tailor the end of the sleeve to fit up against the housing. 90% of the air coming through that hole I cut must pass through the foam sleeve. This keeps most of the leaves and bugs out of the opening and from clogging up the filter.
The hole I cut is about 3" across and 2.5" from top to bottom. I used a Dremel.
This is the AIS filter after 20k miles. LOTS of life left in it. Just knock the bugs and other larger debris out at each oil change. Those who say the filters are expensive don't understand how long they last. The price is a wash compared to the 4 or 5 stock filters you would go through before replacing ONE of these.
Old Mar 7, 2013 | 04:05 PM
  #38
stevestroke01's Avatar
stevestroke01
I agree 100%
<table id="ncode_imageresizer_warning_5" class="ncode_imageresizer_warning" width="400"><tbody><tr><td class="td1" width="20"></td><td class="td2"></td></tr></tbody></table>
Old Mar 7, 2013 | 05:23 PM
  #39
MiamiPSD's Avatar
MiamiPSD
great pics nicmike
Old Mar 7, 2013 | 08:19 PM
  #40
Tugly's Avatar
Tugly
Nicmike's photos prompted me to have another look at my mess, and I guess I hid the ugly part pretty efficiently. I just remember it being a disaster when looking at the outside of the housing (which is hidden, thankfully). Good thing I checked, I had to clean out all the wildlife (flock of moths) that the 38R sucked through the grill and up hard against the filter.
Jimmy Mac
Dec 29, 2010 11:08 PM
kevker2001
13
Jan 28, 2008 07:31 PM
That_Guy
Dec 21, 2007 05:18 PM
Rick2001
Nov 25, 2006 12:17 PM
1fastroadking
Oct 10, 2005 10:26 AM
