Kwik Filter
Old Oct 9, 2005 | 04:10 PM
1fastroadking's Avatar
1fastroadking
Kwik Filter
Anyone out there have a picture of the stock airfilter box or whats left of it just before they installed the Kwik filter (6637). I have seen a few pictures of the filter installed but I want to get an idea of what I have to remove under it.
If by some chance I did not want to chop up the box for this mod what would be the second choice for a filter that fits into the stock box.
Thanks
Richard
Old Oct 9, 2005 | 04:15 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Check Kwik's gallery. I think he left the airbox intact.
The first gen. AFE just replaces the stock lid, and there are several panel filter replacement elements available.
Old Oct 9, 2005 | 04:34 PM
Kwikkordead's Avatar
Kwikkordead
The airbox had to come out. Not enough room and the filter completly fills the space left behind.
Old Oct 9, 2005 | 04:48 PM
1fastroadking
Kwik Filter
Thanks Kwik
Did you have to cut or chop the box up or is it just and unbolt and unsnap the parts issue . Just wondering if you could reinstall the stock box and filter at a later date if you wanted.
Richard
Old Oct 9, 2005 | 04:49 PM
cookie88's Avatar
cookie88
FTE Emeritus
That's right....but you split the airbox and left the battery holder in place right?
Old Oct 9, 2005 | 06:02 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
i left the bottom of the airbox on, and the front part (rear of the battery cover). i did take out the "snorkel" to the grille, and the top/back part of the airbox. the end of the filter sits in a little ledge between the edge of the airbox (it is stepped) and the fenderliner (i think it is the fenderliner). it holds it in there nicely. i am debating on the ZooDad mod..
Old Oct 9, 2005 | 08:08 PM
johnny8's Avatar
johnny8
i used a 3" or 3 1/2" hole cutter on my 3/8" drill, (not sure which), to do the zoodad mod.... it was very easy to do... 10 minutes... and what i noticed is that the under hood temp comes down to ambient within a couple of minutes of taking off... we'll see how this does when the weather gets bad... btw... i left the snorkel on, so all the cool air that gets forced down that snorkel comes out right by the 6637...
Old Oct 9, 2005 | 08:11 PM
PowerstrokeJunkie
thanks for the tip. i guess next weekend ill do the zoodad- no problems of the water going in the intake? im skeptical about that... i will put the snorkel back on too, thanks.
Old Oct 9, 2005 | 09:56 PM
Kwikkordead
Correct. I even reinstalled the battery cover with the Zoodad passage so that cool air would be flowing to the filter while underway.
Old Oct 10, 2005 | 07:42 AM
warrens250's Avatar
warrens250
Thanks
Richard
Richard:
The filter airbox separates from the battery cover/box and snorkel, so remove it and see if the kwik filter fits into the space ok. If not, and you have to chop on some plastic, see below.
What I did was keep an eye on this forum till I found someone who converted or is about to convert to an aftermarket air intake system. (Like a severe duty AIS or one of the other commercial systems.) Send him a PM and ask for the original air box. I did, and got the entire system, from the snorkel back, for a sensible price plus shipping. A whole lot less expensive than buying a replacement from Ford. Now I have a complete fall-back if I decide to get out of the Kwik system.
Warren
PS: After converting, I can't think of a reason why I'd want to go back. WSN
Old Oct 10, 2005 | 07:51 AM
johnny8's Avatar
johnny8
i'm sure that a little water goes down that snorkel, but the water would have to make a 90 degree turn to get to the filter when it comes out the other end of the snorkel, not very likely, i would think that any water that makes it through the radiator to the fan would cause more of a problem as the fan would spray it all over, but that doesn't cause a problem... anyway... i am going to keep an eye on this... i crossed a road yesterday that was flooded with about 3 feet of water and i didn't go slow like i should have... something about splashing water with my truck..! brings out the kid in me..! no problems with the filter....
Old Oct 10, 2005 | 10:26 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
As mentioned in a previous post last week, I have had no problems with water either, and it rains a lot up here. By the way, I just changed out my Kwik filter for the first time after 8 months or so and it was still in good shape. Fleet Filter has great pricing on them too-
PoWeRsTrOkEdF250
88
Dec 18, 2008 01:16 PM
Oakroadjoe
Nov 18, 2008 05:03 PM
nubby3
Mar 22, 2006 03:20 AM
MentalState
Aug 3, 2005 10:53 PM
QFD90
Jun 20, 2005 09:46 PM
