6637 question
Old Nov 24, 2006 | 09:53 PM
Rick2001's Avatar
Rick2001
6637 question
If you do the 6637 intake mod...
do you just remove your stock air box? or do you cut it?
Old Nov 24, 2006 | 09:55 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
You remove the top, and the back. I left the snorkle in place, and i also left the bottom which is part of the battery box. There is also a partition between the battery and the new filter, which i guess was the front of the old airbox. The new filter sits perfectly in a nice ledge on the bottom of the battery ledge.
Old Nov 24, 2006 | 10:00 PM
Rick2001's Avatar
Rick2001
How much do the filters go for?
Old Nov 24, 2006 | 10:05 PM
PowerstrokeJunkie
They can be found at a local Napa (Part 6637) for $40ish, or at www.fleetfilter.com (part 46637) for $18 last time i checked.
Old Nov 25, 2006 | 12:17 PM
jchamb11's Avatar
jchamb11
Hi guys , I made this change this am. I purchased a 4"x4" rubber coupler at Lowes . I was a little concerned with a small gap that was caused by the locating tab for the stock camps, I removed it and the gap was gone. I did run a bead of sealer on the intake tube side to the coupler. The coupler to fiter side tightened up nicely. Used tie straps to hold the sensors out of the way. One large strap to hold the filter to the tray.
Thanks for the help in the all of the past posts.
smash fascism
34
Apr 26, 2011 11:05 PM
JOHN2001
Mar 17, 2011 10:08 PM
69Cobra
May 28, 2010 08:38 AM
tndiesel
Mar 9, 2009 04:14 PM
kent's f-350
Jan 6, 2008 11:39 AM
