AIS Filter Conversion
Old Mar 5, 2013 | 12:24 PM
Big Sky's Avatar
Big Sky
I have been looking around for a used Ford AIS Filter set up and have found some online. One was without a battery tray. Is the stock battery tray not compatible with the Ford AIS?
Old Mar 5, 2013 | 01:39 PM
twg1966's Avatar
twg1966
Trying to Gain Knowledge
Good question. I want to do this mod as well. But I will be waiting a while for that one.
Old Mar 5, 2013 | 02:16 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I am converting my 6637 to AIS this week. You can buy a NEW filter set up on amazon for $180.
Old Mar 5, 2013 | 02:17 PM
Brother Les's Avatar
Brother Les
I do not think that the stock box is compatible with the Ford AIS. Stock is 'rectangle' and these are ''oval'. Not even a close fit.
Ford AIS Replacement Filter 99-03 73.L Ford Powerstroke FA-1757
Ford AIS Severe Duty Intake Installation for 1999-2003 7.3L Powerstrokes .: Articles
Old Mar 5, 2013 | 03:25 PM
Big Sky's Avatar
Big Sky
I don't want to keep the stock box, want to convert to the new set up.
Old Mar 5, 2013 | 03:32 PM
cj45lc's Avatar
cj45lc
You need the batt tray that comes with the AIS
Old Mar 5, 2013 | 03:55 PM
F250_'s Avatar
F250_
Where on Amazon? Link, please.
Old Mar 5, 2013 | 04:20 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Hes not talking about the filter, just the battery tray.
Kit:
Motorcraft FA1759 Air Filter : Amazon.com : Automotive Motorcraft FA1759 Air Filter : Amazon.com : Automotive
Extra Filter:
Amazon Amazon
Its a little gem I found several months ago. Hidden with the Ford Parts Part Number
Old Mar 5, 2013 | 04:31 PM
Supercab's Avatar
Supercab
Guys, heres MY take on the EXPENSIVE AIS setup AND the 6637:
The AIS IS EXPENSIVE, the replacement filter for it is EXPENSIVE!
The 6637 (sorry guys) is crude, I don't like crude under MY hood
MY LATE '99s air box is in good condition, NOT cracked and seals well with anything OTHER than a K & N filter in it.
This all said I run either a PUROLATOR PURE ONE filter OR the FRAM equivilliant which I believe is called a "Tough Guard" both cost about $15.00 each, sometimes less on that auction site, and I ALWAYS get GREAT oil reports from Blackstone that indicate my AIR FILTER is working WELL.
I personally do not see any reason to fool with success, nor spend any extra $$ on stuff that just isn't needed.
Old Mar 5, 2013 | 05:30 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
[FA-1759]Ford 7.3 liter Power Stroke Diesel AIS Extended Life Filter Kit(FA1759) - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
My filter for my AIS will last 3 years EASY. The initial buy in is high, but the filtration is better than stock by far. Air flow is better to the turbo as well when compared to stock. Glad I bought mine!
Old Mar 5, 2013 | 07:17 PM
srteach's Avatar
srteach
To answer the question clearly, the OEM (non AIS) filter setup has a battery tray attached. When you remove the OEM one, you remove the battery tray.
If you want, you can cut the battery tray apart from the airbox and use it with the AIS system. The battery clamp (which secures the battery) is weakened without the box.
Old Mar 5, 2013 | 07:24 PM
honeydew's Avatar
honeydew
The battery tray that comes with the AIS is metal similar to the passenger side battery tray. It might be possible to mount a passenger side battery tray from the junkyard on the driver side to replace the airbox/tray. It's been a while since I've had the batteries out and I can't remember how the trays mount.
Old Mar 5, 2013 | 08:56 PM
crop harvester's Avatar
crop harvester
after seeing a little dust getting by the oem filter the ais was a small price to pay to stop that nonsense,it looks stock & very easy to pull filter.
Old Mar 5, 2013 | 11:58 PM
Bonanza35's Avatar
Bonanza35
Mike dose this come with a battery tray? It dosen't show it in the picture. Thank you,
Chet
Old Mar 6, 2013 | 05:03 AM
Tugly's Avatar
Tugly
I go 20,000 miles (agricultural environment) on each filter before my 30 PSI+ boost turbo says "Uh... Tug? Got air?"
When you install an AIS, use the stock filter minder, the AIS unit trips earlier.
File Type: pdf
