Trouble with power steering
Old Mar 4, 2013 | 05:25 PM
trab's Avatar
trab
Hey guys ive been having this problem for about 6 months now. When i purchased the truck it had a steering whine / groan while turning and was loosing PS fluid. It is also very hard to turn while at a dead stop. Sometimes it will be easy to turn at a stop then seconds later really hard. Also if my fluid get just a HAIR low the groaning will get really loud and my brake pedal also groans until i get more fluid in it (i have to almost fill it to the top of the resovior). I figured the power steering pump needed to be replaced, well i replaced it today and it didn't change a thing besides it isnt leaking anymore that i know of. The shop that put in the pump told me that i need a new hydro-boost but im not sure thats it. Wanted to get some input before putting in something else. Thanks
Old Mar 4, 2013 | 11:47 PM
firedaniel's Avatar
firedaniel
It does not use ps fluid. It uses transmission fluid. I would flush the powersteering fluid out use a good mercon transmission fluid. It made a nice difference on mine. I would do this first
Old Mar 4, 2013 | 11:49 PM
firedaniel's Avatar
firedaniel
https://www.ford-trucks.com/forums/1...ing-whine.html
Check out this thread. There is a link to how to flush it
Old Mar 5, 2013 | 01:51 AM
Yahiko's Avatar
Yahiko
Because you have a diesel and don't have a large vacuum pump
your brakes are operated by the power steering system hydraulic
pressure. That is what the hydro-boost system is. If you open the hood
and look just behind the brake master cylinder on the firewall you will
see some hoses that come from the Power Steering pump. If you replace
the fluid you also want to pump the brakes to force the fluid out of the
accumulator. That is why you have brakes when the motor is off. The accumulator
stores some fluid under pressure so that you have 2 or 3 shots at the brakes.
Sean
Mike Mccord
Mar 13, 2017 11:30 AM
0500757Arf
Oct 15, 2016 09:08 PM
titanminator
Mar 30, 2012 10:24 AM
texasjack
Jul 23, 2010 03:15 PM
03_PSD
18
Oct 10, 2008 03:32 PM
