? was anybody turning the steering wheel with engine off, or is it overfilled. and with the correct fluid. this was some of the questions that were asked to others that had this problem . never heard feed back on there fix. somebody with more experiance will be more help.
If I try to turn mine with the engine off fluid will pour out of the pump.
titanminator what type of fluid did you refill with? Many here have replaced with the Mobil1 ATF and have had quite a bit of the steering pump whine eliminated.
Mercon V and as I shut the engine off with my foot on the brakes is when I smelled at fluid. Looked under the hood and cap is full with fluid seeping from the cap
