Power steering pump whining?
Old Jul 23, 2010 | 06:50 AM
texasjack's Avatar
texasjack
2000 7.3 auto 2wd,The power steering pump makes a noise as if its out of fluid when I hit the brakes or turn the steering wheel. Is it trying to tell me to replace it? I've had issues with this trucks brakes forever.
Old Jul 23, 2010 | 07:19 AM
Smokin''s Avatar
Smokin'
Smokin
Have you checked the fluid levels? What type of fluid do you have in there, is it power steering fluid or ATF?
Also, does it look brown or smell burned in any way? You could try flushing your power steering pump, I bet it would make a world of difference.
Old Jul 23, 2010 | 07:55 AM
texasjack's Avatar
texasjack
Trans fluid. No burnt smell.
Old Jul 23, 2010 | 08:02 AM
izzybird's Avatar
izzybird
If you do the flush, replace the fluid with some synthetic atf. I used mobil 1, and it made a huge difference on my dads truck. Not so much on mine. An quality inline filter can't hurt either.
Old Jul 23, 2010 | 08:09 AM
DND58's Avatar
DND58
Here's a link for the flush if you go that way.
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Jul 23, 2010 | 01:04 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
I had the very same problem for a a year and 7 months and couldn't quite figure out what it was...I finally found out last saturday: https://www.ford-trucks.com/forums/9...a-weekend.html
Old Jul 23, 2010 | 01:20 PM
empiretc's Avatar
empiretc
when mine did that years ago, I added a little STP (honey colored stuff) and it has not whined since.
Old Jul 23, 2010 | 02:57 PM
Toreador_Diesel
Can you provide a link?
Even though I replaced my lines and there are no leaks, mine is still slightly whining...just enough get on my nerves....
Old Jul 23, 2010 | 03:15 PM
texasjack's Avatar
texasjack
Nice write up on the lines. I'll check those. Ive changed the pump about 3 times, brakes never seem to work correctly. I hate those lingering problems...
Roger C
Feb 16, 2017 09:57 AM
Zeropowerstroke99
22
Dec 1, 2016 08:04 PM
Deanp88
6.4L Power Stroke Diesel
May 23, 2016 08:15 PM
quality1construction
26
Feb 27, 2012 08:47 PM
jdr37
Aug 11, 2009 06:30 PM
