my truck just started to make a buzzing sound when you turn. it does it turning both ways. im thinking my power steering pump is getting weak or maybe i should change the fluid. what do yall think?
Yeah, but I can tell you faster than I can find it. Unhook your return line from the brake booster and attach a clear hose long enough to run to a gallon jug. Open your pump reservoir cap and crank engine. Using a LONG neck funnel, add new fluid to reservoir as you have someone slowly turn the wheel and work the brakes. You will see the old fluid coming out of the clear tube. When the fluid turns a pretty red (new fluid) your done. It will that right at 3 qts, but have the forth handy just in case. As long as you don't run the reservoir empty, air shouldn't be a problem.
Yes, syn. works very well.
You can pull the low pressure hose off the pump and have someone start and stop the engine as you add fluid to the resivoir. try to not get an air bubbles in there but they can be purged.
I guess you could also pull the serp. belt and use a drill an short belt to turn the pump much slower an do it by yourself.
Isn't another trick to get air out to turn the wheels all the way one way and leave it overnight, then the turn them the opposite way and leave it the next night? I thought I read that someplace... BTW, mine was whiny and after putting in the syn ATF, it got nice & quiet. I can still hear it, but just a little. My Ranger was a whiny b!tch, and I never swapped it. It ran that way for 92k before I traded it for my '250.
How do you crank it without it running? Can you hit WOT and have it go into clear flood mode?
Unplug the CPS....thats what I did to clear the old fluid outa my new powersteering pump, pump still whines like crazy but im not here to hijack his thread!
