Sponsored by: Auxito
which oxy. sensor?
Old May 29, 2010 | 01:36 PM
poseidon's Avatar
poseidon
which oxy. sensor?
I have a 99 f150 4.6L 2 wheel. Code po141-Bank 1 Sensor 2 ---which rear sensor is this??
Old May 29, 2010 | 01:46 PM
powersmoked's Avatar
powersmoked
Bank 1 is Passenger side. sensor 2 is after cat. what is the code. the after cat sensor for the most part do not affect engine management. they are there to report on the cat
Old May 29, 2010 | 01:59 PM
poseidon's Avatar
poseidon
Thanks for the quick response! Again--the code was PO 141
Old May 29, 2010 | 02:30 PM
powersmoked
my bad I did not see the code # earlier. " sensor heater circuit" you should check the connections on it but my guess is that it is bad. Again the after cat sensor are really just for reading info for the cat not managing the engine( I know some people will argue with me about this)
That code is for the heating elemnt of the sensor
Old May 29, 2010 | 04:11 PM
93 mix 'n match's Avatar
93 mix 'n match
yes, the second sensor is to report on the cat. it takes info from the front sensors, compares them with the rears, and determines if the cat is functioning properly. the fronts control the fuel mixture.
svtcobra041
1997 - 2003 F150
Jul 15, 2010 09:19 AM
bigredball90
1983 - 2012 Ranger & B-Series
Oct 20, 2009 07:21 AM
bigcrunch
Oct 12, 2009 06:30 AM
870
Feb 15, 2008 09:23 PM
rgreen01
Jan 3, 2005 12:25 PM
