weiand stealth - hood clearance & linkages
I sold my work beater and i got 500 bucks to play with.
figuring on an edelbrock carb (cauz im familar with them) and an weiand stealth intake. this is for my bone stock 79 F-350 w/460-C6-2wd w/4.10's.
my only real concerns are hood clearance and the AT kick-down. As i look at it, The stealth intake is a hi-rise of sorts so i'm wondering if i should expect any problems with the AT linkage or hood clearance.
on a side note .... edelbrock has their standard performer and their AVS.
is the tunable secondary damper a big deal? i've only had experience with the regular performer.
I've thought very long and hard about trying the summit carb, but i don't like the nature of the secondaries on a tow rig. i would like to stay out of the secondaries and know that i'm staying out of them, unless i need or intend to do otherwise.... my stock carb has the vacuum actuated secondaries and i really don't care for it much. mileage is good when not towing but atrocious when loaded ... so that's why i'm leaning toward the edelbrock.....
thoughts?
thoughts?
your truck is a true work of art!
thanks for the pics, that helps and gives me a few ideas. It looks as though hood clearance shouldn't be a problem. If i use the stealth i woudn't use a spacer, and it looks like you have room even with a spacer?
i found a throttle cable and kickdown cable on summit:
AutoLoc Kickdown Cable Kits KCBL12 - SummitRacing.com
AutoLoc TCBL2 - SummitRacing.com
the prices arent bad....
here's the homepages:
AutoLoc Black Universal Throttle Cable « autoloc.com
AutoLoc Ford C-6 Kick Down Cable Kit « autoloc.com
the kickdown cable is an unknown for me. i can't envision how a cable will work on a C6, i'm sure it is straight forward, but it is different than the rod type.
i think i need to get under the hood of the old dog and see how mine is put together... i can't seem to figure out what you have going on there. I'm assuming the upper most rod is the kickdown cable?
poor picture, but here's how mine is stock:
orange rod is the kickdown, with the throttle cable and cruise control cable below that.
thanks in advance....
Thank you for the compliment. I appreciate it very much. The red bar is the throttle linkage. Don't pay over $25 for one. Below is a link to Summit. I used a standard Northern Tools tube bender that cost about $10 to bend it the shape that I wanted. It is threaded so you can cut it the proper length as well. The Lokar kickdown cable is a little over priced, but it is a good quality and looks nice. I found it a little troublesome to mount the bracket on the transmission, but I'm not the sharpest tool in the shed. Good luck and let me know if I can help further.
Allstar Performance Carburetor Linkages ALL54162 - SummitRacing.com
i'm wondering if i couldn't get two of them and extend the factory kickdown rod in the same way. that would be cheaper than a cable kit.
i love the way yours is set up, looks killer.
Here is what I think you need if you want to just use your factory kickdown linkage:
http://www.edelbrock.com/automotive_.../1000/1483.pdf
Do a search on the part to be sure, but I think it will work just fine. Good luck.
As for the spacer, it just gave me a little more room up front for the HEI distributor and the fuel lines. I hope it wasn't a bad decision. Could there be any problems by using the spacer?
i'm thinking it might be a wash money wise either way i get there. whether it be a cable set-up, or the adapter and extending the factory cable.... have to think on it a while.
im rather excited to use the weiand over the edelbrock. nothing wrong with the edelbrock, but i just think the added plenum volume of the weiand will be a benefit.
thanks for all the pointers and pics!
love this forum!
brownd019
1966 - 1977 Early Broncos
08-16-2009 02:36 PM
Ranger1F150
1978 - 1996 Big Bronco
05-19-2007 10:21 AM
justshootme84
17
05-09-2003 12:57 AM
