axel wedges?
Old Feb 26, 2013 | 07:13 PM
buzzy613's Avatar
buzzy613
axel wedges?
i replaced my rear u joint and nloticed the angle of the drive shaft loked about ready to bind up, the yoke on the axel is straight with the drive shaft on about a 15*-25* angle and i was wondering if axel shims would corect it and if i should correct it.
Old Feb 26, 2013 | 07:26 PM
88dually's Avatar
88dually
yoke to yoke should look like a straight line
Old Feb 26, 2013 | 07:39 PM
buzzy613's Avatar
buzzy613
wel mine are deffinatly not in a straight line, so i should look in to getting axel wedges?
Old Feb 26, 2013 | 07:40 PM
88dually's Avatar
88dually
my 96 was an my 88 is,so i'm going by those
Old Feb 26, 2013 | 08:24 PM
buzzy613's Avatar
buzzy613
so the yoke on the driveshaft was directly in line with the yoke coming out of the pumpkin... this now conserns me...
Old Feb 27, 2013 | 09:56 AM
garthneddy's Avatar
garthneddy
For a conventional two u joint shaft, the centerline of the transmission and the differential need to be parallel
Old Feb 27, 2013 | 10:24 AM
buzzy613's Avatar
buzzy613
alright so just leave it how it is?
Old Feb 27, 2013 | 12:45 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The universals at each end of the shaft need to have the same angle, otherwise they will be destroyed in short order.
You can't just point the pumpkin at the output.
https://www.google.com/search?q=pini...w=1143&bih=555
finneys98xj
May 11, 2011 02:17 AM
partsman01
Jun 25, 2005 07:00 PM
masterbeavis
Sep 13, 2002 09:46 PM
jphillip
1978 - 1996 Big Bronco
Apr 2, 2002 10:40 AM
Ed Bamba
Apr 6, 2000 07:40 PM
