drive shaft angles
Old Apr 5, 2000 | 05:11 PM
Ed Bamba's Avatar
Ed Bamba
drive shaft angles
Old Apr 5, 2000 | 09:10 PM
pgood52636's Avatar
pgood52636
drive shaft angles
does anyone know the angles for rear on a 89 F150 shortbed 4x4?
Thanks
Paul Goodman
Old Apr 6, 2000 | 05:51 PM
Phillip Guidry's Avatar
Phillip Guidry
drive shaft angles
Basically, if you want to drive fast without adverse wearing out of the u-joints, the pinion must point directly at the yoke at the transmission. In other words, only the front u-joint should handle the angle.
Phillip
Old Apr 6, 2000 | 07:40 PM
Nathan's Avatar
Nathan
drive shaft angles
If your driveshaft has a CV joint at the transmission end, the pinion should be in line with the driveshaft. (A CV joint is two universals with a ball and socket between them.) If no "CV", then the angle should match the angle at the trans. or t-case.
Nathan
