2009 window problem
Old Feb 17, 2013 | 04:24 PM
Gmanmacha's Avatar
Gmanmacha
2009 window problem
Has anyone had this issue, rear power windows work intermittently, one was stuck down so I manually raised it. tested both sides by removing motors & switches still no power to raise. Then suddenly they worked. Then again stopped working. Now I cant even control them from the front. I used the front switches to elimate a switch problem, still existed. Tested the motors as well and all are fine.I tried the motors on each switch and they only worked in one direction then worked & so on. I heard this may be a harness problem but where ? I dont believe the switches or motors are faulty due to thefact they are having the same issue and too much of a coincidence that both have same problem at the same time. Any suggestions? Thx George
my79f
18
Sep 11, 2010 12:28 PM
barnbuoy
Dec 7, 2008 07:51 PM
utahtom
Jun 30, 2008 07:36 PM
OKEBBronco
1978 - 1996 Big Bronco
Mar 12, 2008 10:24 AM
OldEx
Nov 3, 2001 01:40 PM
