Sponsored by: Real Truck
Power window problem?
Old Jun 29, 2008 | 11:06 AM
utahtom's Avatar
utahtom
My power windows occasionally stop working. All of them including the power rear slider. Then a few minutes later everything is fine
My theory is that the driver's side window switch is failing and needs replacement. Any ideas or recommendations?
Thanks, Tom
Old Jun 30, 2008 | 07:36 PM
ReAX's Avatar
ReAX
That sounds about right. You might be able to trace it all out and see if you lose continuity in the switch.
Once it stops, have you tried the other switches? There is a lock out switch on the drivers switch so it is possible that if the switch fails it takes the others with it. Perhaps someone can tell you the wires to jump to bypass the drivers switches' power to the others.
