Sponsored by: Auxito
differential
Old Feb 15, 2013 | 01:58 PM
jdq's Avatar
jdq
differential
2002 ford f150 xl
what fluid should be used on differential fluid change ?
is it straight drain and fill plug.hex
Old Feb 15, 2013 | 03:54 PM
LucasMN's Avatar
LucasMN
Originally Posted by jdq
2002 ford f150 xl
I didn't notice the search button was broken.
75w-90 for front. Drain and fill plugs. Make sure to remove fill plug first.
75w-140 for rear + 4oz friction modifier. - Remove fill plug, then remove diff cover. There is no drain plug.
Old Feb 15, 2013 | 04:50 PM
Spotty's Avatar
Spotty
I know mine has a tag on the diff. that says what kind to use.
Old Feb 15, 2013 | 09:20 PM
steve(ill)'s Avatar
steve(ill)
FORD recommends synthetic in the rear. Old spec was 75 w 90 , new spec is 75 w 140 (rear) . Striaght old 80-90 gear lube in the front is fine.
dracond
Jul 22, 2015 06:08 AM
VaFordman26
Jul 5, 2014 02:33 PM
DieHardChief
21
Nov 14, 2013 08:55 AM
trackfactory
May 29, 2011 04:33 PM
l. norwein
Aug 6, 2007 02:18 PM
