differential drain/fill
Old Aug 5, 2007 | 06:33 PM
l. norwein's Avatar
l. norwein
I replaced rear axle seals on my '95 F-250. When I went to fill the differential I can find no evidence of a drain/fill plug. I removed the cover and tried to see any area that could contain such a plug - no help. What do I do to fill and later check the rear end fluid? Thanks
Old Aug 5, 2007 | 06:36 PM
Josh88Ford's Avatar
Josh88Ford
should be on the 3rd member. square hole. ratchet fits into it...
Old Aug 5, 2007 | 07:05 PM
Skandocious's Avatar
Skandocious
To drain you must remove the diff cover. To fill, there is a 3/8" ratchet drive nut (square) on the front side of the differential (towards the front of the truck) near the pinion where the driveshaft comes into the diff, can't miss it.
Old Aug 6, 2007 | 02:18 PM
l. norwein's Avatar
l. norwein
Thanks for the quick response. Sounds like a simple solution.
