Changing rear diff fluid on a 10.25
Old Jul 5, 2014 | 01:50 PM
VaFordman26's Avatar
VaFordman26
Hello I have an 89 F250 thats got a sterling 10.25 in the rear and I would like to change the gear oil. I have changed many Dana 60s, 44s, and 35s. It seems to be the sane deal here just pull off the cover to drain but I dont see a drain plug.
Also what weight gear oil should i put in it? It does not have a LS. Is 90 good?
Thanks
Old Jul 5, 2014 | 01:55 PM
Conanski's Avatar
Conanski
Pull the cover and clean it out best you can and then put it back on with some fresh RTV. Then remove the fill plug located on the pumpkin side above centerline and fill to the bottom of the hole with 80w90.
Old Jul 5, 2014 | 01:58 PM
VaFordman26
Thank you thats what i thought. And I meant to say i didnt see a fill plug not a drain plug.
Old Jul 5, 2014 | 02:08 PM
VaFordman26
How much oil will it hold?
Old Jul 5, 2014 | 02:13 PM
VaFordman26
Are you talking about the bolt on the very top of the housing thats holding a bracket for the brake lines?
Old Jul 5, 2014 | 02:33 PM
Diesel_Brad's Avatar
Diesel_Brad
The fill plug is on the drivers/front, just below the webbing.
You need 3/8 drive to unscrew it.
It hold 3.75 quarts And I use 75w/140 oil
DieHardChief
21
Nov 14, 2013 08:55 AM
jdq
1997 - 2003 F150
Feb 15, 2013 09:20 PM
trackfactory
May 29, 2011 04:33 PM
f_pumillo
Mar 28, 2004 07:47 AM
n2umr
Dec 12, 2003 06:45 AM
