bottom mount leveling kit
hey guys, have a question... I have a 3" leveling block that is a bottom mount type... with the shock extension bracket... my question is are the bottom mount spacer just as good as the top mount...? I see that most people use top mounted spacers, or they get different coils all together, and I was just wondering if it's because the bottom mount are worthless or what? if they are good, then I'll just use the one i have, if not then I"ll get a different leveling kit... thanks
link to the same product on Ebay... 3" 1" Full Lift Kit 2005 2011 Ford F250 F350 4x4 Superduty w Shock Extenders | eBay
nobody has any input on this? I understand that it's kinda a cheap leveling kit, but fab tech uses the exact same spacer, only diffference is that they used longer shocks rather then a shock extension bracket...and fab tech is a pretty well talked about brand if I'm not mistaken... so.. no takers? nothing?
oh.. well.. hmm... well if I get it all together and I can see the 1/2 inch difference then I'll get a 2.5... wouldn't be much of a loss to me cause I originally bought it for an '05 f250 5.4 I had.. and never got around to putting it on, and then got rid of it.. so I just happened to still have it 2 trucks later, and saw that it would fit my '08 6.4 so... I plan on measuring before and after, and if it looks like the front is hirer, and I'll either swap the front, or swap the back for a bigger 1 piece block, which honeslty is what i might do anyway caue I'm not a fan of stacking blocks...
All I know is that the Icon replacement springs leveling kit I installed has been terrific so far. I know that many people who have gone higher, or used blocks to lift the front springs have experienced this problem and had to buy the track bar. Here's what I don't understand Countryboy, I am not sure hwat you are driving, but if you have a truck worth more than 20K, why would you cheap out on the suspension, particularly the front suspension?
Well I'm not intentionally trying to be cheap.. I just happen to have the kit... And from what I can tell its exactly the same as the fab tech as far as the front block goes... Only mine is 3" and the other is 2.5... Btw its an '08 250 6.4.... I'm just trying to simply get good advice to see if its alright to use what I have... Ill pay for a top mounted 2.5 spacer if I have to.. But that's why I'm posting cause if I don't HAVE to then I'm not gonna waste the money... That's all im getting at...
