Strut Leveling kit option???
Old Feb 9, 2009 | 07:05 PM
gui88ford's Avatar
gui88ford
04-08 FORD F150 BILSTEIN 5100 LEVELING STRUT @ NTW
anyone use these???
Old Feb 9, 2009 | 07:38 PM
Catmonkey's Avatar
Catmonkey
Rancho has a similar product called a QuikLift. I just installed them on my truck. The Rancho strut is based on their RS9000XL shock and has 9 adjustments from soft to firm. I'm still assessing them, but I like having the ability to adjust the valving in the shock for the ride that's most comfortable.
Old Feb 9, 2009 | 10:01 PM
lakeforkfisherman's Avatar
lakeforkfisherman
I have been looking at leveling kits lately and wondered if there was a strut that would accomplish the same thing. Seems that while I'm under there, might as well replace the struts. Thanks for the post.
Old Feb 10, 2009 | 02:40 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
If you need shocks, do the lift struts.
if your shocks are still good, get a leveling kit. The process of changing out the struts is pretty big PITA. A leveling kit can be installed in about 2 hours if you are wrench handy.
Old Feb 10, 2009 | 07:29 AM
lakeforkfisherman
I wouldn't change the struts myself. I am handy, but no mechanic. I am planning to do the leveling kit myself, but with the help of my brother, who is a gearhead.
Old Feb 10, 2009 | 10:29 AM
dlgentry's Avatar
dlgentry
I have the bildstiens and love em. Did the install myself. You will need a monster sized spring compressor to put the front ones on. The regular ones do not have what it takes to compress the springs. If you don't have it, do yourself a favor and pay some one to do it.(someone who has done it before). 33's will fit after install with no rubbing. 35's will depend on the brand.8d
Old Feb 11, 2009 | 12:33 PM
Drizzt's Avatar
Drizzt
who makes a strut leveling kit? i was planning on replacing both struts anyway but after i had the rear springs replaced it really lifted the rear end up. i would like to level it back out.
Old Feb 11, 2009 | 12:35 PM
Catmonkey's Avatar
Catmonkey
Bilstein and Rancho both make leveling struts for 2WD and 4WD applications. It's Bilstein's 5100 series and Rancho's QuickLift.
Old Feb 11, 2009 | 02:41 PM
Drizzt's Avatar
Drizzt
so do i have to purchase both front and rear? i was under the impression that it was just the front i would have to lift to level it
Old Feb 11, 2009 | 03:00 PM
gui88ford's Avatar
gui88ford
yeah, just the front you would need to level it.
Old Feb 11, 2009 | 05:06 PM
Catmonkey's Avatar
Catmonkey
The rear shocks from the same manufacturer will do nothing but compliment the front struts, but you get no lift from the shocks.
Old Feb 11, 2009 | 06:48 PM
gui88ford's Avatar
gui88ford
i read a couple posts on another site where guys were using this set up and running 35" tires with no rubbing at all. I would think that 2" of lift is 2" of lift no matter if it's from a spacer vs extended travel struts.
i read that guys were getting 3" of lift from the struts
Old Feb 11, 2009 | 09:30 PM
Drizzt's Avatar
Drizzt
do the Bilstein's come with the spring as well as the shock?
Old Feb 12, 2009 | 05:45 AM
Catmonkey's Avatar
Catmonkey
No, it's just the strut. You use your stock springs and some of the OEM hardware.
Old Feb 12, 2009 | 06:13 AM
dixiemudder04's Avatar
dixiemudder04
Y couldnt you jack the truck up by the frame and take out the struts, then put the new ones in and let it back down. Then you wouldnt have to use a compressor right? Just use the weight of the truck.
