wipers work when not on
Old Feb 8, 2013 | 05:40 PM
GTBksRule's Avatar
GTBksRule
I have a 99 f450 and the wipers work when not on. it's this an electrical issue or a bad wiper motor. thx
Old Feb 9, 2013 | 07:26 AM
Franklin2's Avatar
Franklin2
If they keep running when you turn the switch off, it sounds like the cam switch in the wiper motor. They do stop when you turn the key to off correct?
How it works; The wiper motor is fed with two power supplies. One is power anytime the key switch is on. The other comes from the wiper switch. When you turn the key on, power is supplied by one of the wires going to the wiper motor, but the motor doesn't run because this power must run through a cam "park" switch. If the wipers are down in park, it will not run. The power from the wiper switch bypasses this switch, so as soon as the wiper switch is turned on the wipers run.
When the wiper switch is turned off, you still have power applied to the wiper motor from the key on power supply, and if you happen to turn the wiper switch off when the wipers are not in "park", the key-on power supply with continue to run the wipers till they reach the park position, and then the cam switch will open up and stop them.
You must have the wipers mounted to the system to cause drag to the motor for this to work. If you are running the wiper motor with no wiper drag on it, when it comes to the park position, it can turn off and coast through the park zone, and then it will start up again and keep running.
Old Feb 9, 2013 | 08:16 AM
GTBksRule's Avatar
GTBksRule
yes they do turn off when the key is off. So I guess to solve that is a new wiper motor. thx
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
Apr 26, 2016 05:50 AM
1979camperspecial
Nov 30, 2013 01:31 PM
sixing
Electrical Systems/Wiring
Dec 21, 2009 05:42 PM
4byford
Jan 7, 2007 06:23 PM
gskett
Jun 13, 2004 05:54 AM
