FUEL PUMP
Old Jan 16, 2015 | 11:16 AM
  #76
SkySkiJason's Avatar
SkySkiJason
Originally Posted by brettdacosta
Jason,
On the cases you've seen these leaking, where were the leaks coming from? I picked one of these up. It's the one with the plastic threads you have to screw a brass fitting over on the suction side - not the metal barb type. In other words, it's one that looks like an airtex instead of the bosch, and I'm either having a hard time getting mine to seal or it's leaking somewhere.
I'm wondering if I tightened the brass fitting down too much and stripped the last thread out causing it to just keep spinning and never getting tight. Or if my leak is coming from somewhere else on the pump.
Thanks in advance,
They leaked where the metal case is crimped at the end.
Old Jan 16, 2015 | 04:00 PM
  #77
brettdacosta's Avatar
brettdacosta
Which end usually leaks? Inlet or outlet side?
Thanks.
Old Jan 16, 2015 | 04:53 PM
  #78
DieselDenny's Avatar
DieselDenny
5400 miles, no issues. Still spinning up nicely.
Just sayin and no leaks.
Denny
Old Jan 16, 2015 | 06:20 PM
  #79
mototrig's Avatar
mototrig
I gotta say for the price I'm keeping one behind my seat in the event my OEM one goes out. I'd still replace it with another OEM pump once I get back to home. I'm sure it's a solid enough pump to last as an emergency backup and probably longer
Jefff H
6.7L Power Stroke Diesel
31
Oct 24, 2012 08:07 AM
Wynn96
Aug 6, 2009 09:12 PM
jasonw302
Jun 16, 2005 07:35 AM
