bumpy box floor
Old Feb 5, 2013 | 12:13 PM
lefty rodan's Avatar
lefty rodan
bumpy box floor
While stripping the paint from my 65 pickup box floor I found about 8 "pooched up" spots running crosswise on the floor where it is spot welded to the rear box crossmember. My first thought was rust out but there doesn't seem to be any rust above or below the floor. The metal seems solid.
My thinking is that after almost 50 years of absorbing bumps the harder spot welded areas have forced the softer metal above to stretch.Other than that the box is exceptional.
Any suggestions on how to deal with this?
Thanks for your time. Lefty
Old Feb 5, 2013 | 04:27 PM
jmf66's Avatar
jmf66
It may have been severely overloaded at some point in its life. Got pics?
Old Feb 5, 2013 | 06:00 PM
schoo's Avatar
schoo
Just sold my 57-60(wrong bed)was like the Bering sea wave after wave you get sea sick looking at it
Roy
Old Feb 6, 2013 | 09:06 AM
lefty rodan
Thanks for the replies. I have to agree that overloading mabe the culprit. I haven't yet mastered the photography yet but I think it would be very difficult to see the "pooches" in a photo. I'm going to try to work them down with heat shrinking and hammer and dolly. If that doesn't do it I'm thinking about using a hole saw to drill out the stretched metal from below--going through the crossbrace and then plugging the hole with circular metal blanks.
The thing about that approach is that I haven't found a source of solid circular blanks other than knock out plugs from electrical boxes. Any other ideas along that line? Thanks again. Lefty
Old Feb 6, 2013 | 11:03 AM
carras's Avatar
carras
I used an air hammer with a flat attachment to hammer out any dings and high/low spots in my bed. It didn't come out perfect, but did improve things a bit.
Old Feb 6, 2013 | 03:12 PM
jmf66's Avatar
jmf66
They make a knockout punch kit that you can make the round blanks. It'll take some work to weld these in and then do the body work to hide the patches.
Knockout Punch Kit - Knockout Punches at Harbor Freight Tools
Another option might be a machine shop to punch out some blanks for you .
Old Feb 7, 2013 | 01:26 AM
jpbecker's Avatar
jpbecker
It sounds like you're describing something we call "oil canning" in the aviation community. Called that because of the popping sound it makes when pushed back and forth. It's usually more of a nuisance than a structural concern. Best long term fix is to trim out the areas and do a "flush patch". Two patches, one the exact size of the hole, the other just larger. The little/inner patch is spot welded to the larger/outer patch The outer patch is of course welded to the cab floor outside. Makes it really durable and keeps your floor smooth. I hope that makes sense.
Old Feb 7, 2013 | 10:49 AM
lefty rodan
Thanks for the replies. Forgot about the knockout punches, I think I have a set but not sure they will punch 16 gauge. The metal is not oil canned in the normal sense that it is stretched Using the two blanks might be a solution.
Lefty
jamhh
Dec 18, 2015 12:30 PM
vintage tin
24
Apr 2, 2014 11:36 PM
Boss9F100
Nov 27, 2012 02:47 AM
KawiRider78
20
Jun 3, 2011 10:06 AM
jeff303
Paint & Bodywork
May 15, 2004 08:54 AM
