But its NOT Producing 110amps at Idel by any means
IDK what the Actual specs are for the 110amp OEM Unit are but it might scare Ya
I've seen specs from anywhere of 45 amps at idle to 60 amps.
You see in Mustang's video he has a normal system amp requirement of around 60 amps at idle, that is why the stock 6G can only muster mid to high 13's for voltage. It's being taxed at idle and cannot handle it.
Right when the Truck Starts and Runs I hit 12.7-12.8volts
then it Trickles up into the 13+ volts range
Then GP shutoff and it Jumps 14.0-14.5V or so
I added 0.20volts in this number^^Number with SGII OBDII Port
I would have to watch Closer next start
It was at 12.8volts the first 5 Seconds or less and I walked away It always gets better from there so I Didnt Veiw the Volts Gauge this AM on the First Crank today
I wait to start for the first time till the vac pump has stopped.
That gives the glow plugs a bit more time to heat the surrounding
area and I think it starts easier IMHO.
If you really want to know you can set the Xgauge in your SGII
to show the glow plug time on in seconds.
