Deltas after adding coolant filter
Old 01-31-2013, 09:09 PM
altruego's Avatar
altruego
altruego is offline
I installed a coolant filter yesterday on my 2005 F-350 PSD. No issues with the install. I got a chance to take it out on the open road today and I noticed my EOT/ECT deltas are 2 degrees higher than before installing the coolant filter.
Deltas before the filter install were 6-8 degrees. After the install 8-10 degrees.
Has anyone else seen this? My theory is the the small amount of coolant leaving the block early is lowering the ECTs a few degrees. But I am a little puzzled.
The outside temp was in the high 40's.
Old 01-31-2013, 09:38 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
What was ECT at when you took the readings????190*??
Are all your ECT & EOT & TFT the same or within 1 or 2* after a 12 hour cold soak???? At Startup
Old 02-01-2013, 09:54 AM
altruego's Avatar
altruego
altruego is offline
The cold soak temps are spot on.
The ECT didn't go up to 190. The max I saw was 188 which kind of confirms the fact that the small amount of coolant going around the bypass filter is causing the engine to run a few degrees cooler.
If i get a chance today I will do some tests with shutting the bypass and watch the temps and then open the bypass and see what changes.
Old 02-01-2013, 10:20 AM
ChrisAU's Avatar
ChrisAU
ChrisAU is offline
Why would the small amount of coolant going around the bypass cause the engine to run cooler? You aren't bypassing the t-stat.
Old 02-01-2013, 01:35 PM
altruego's Avatar
altruego
altruego is offline
I'm pretty sure the coolant bypass circuit is not bypassing the t-stat
Old 02-02-2013, 03:04 PM
bpounds's Avatar
bpounds
bpounds is offline
Delta temps are constantly changing as engine load changes, outside air temp changes, etc. I don't believe you can really say you have 2° difference after the install. The values are not steady enough to make such a precise determination.
Relax. Don't worry. Be happy.
Old 02-02-2013, 03:27 PM
BLADE35's Avatar
BLADE35
BLADE35 is offline
I agree with Bill^^^
2* is Nothing
188* ECT is very Common Hell thats where my truck runs
Old 02-02-2013, 03:39 PM
bpounds's Avatar
bpounds
bpounds is offline
Actually it does. Your t-stat limits flow to the radiator, so that the engine will warm up and maintain a constant temperature. Your heater core uses coolant directly from the engine, and is not controlled by the t-stat. The coolant filter installs in the heater core circuit.
I don't really think there is enough extra cooling from the filter circuit to make any difference in what you see on a temp gauge. Like I said, the temp is constantly moving up and down, and you wouldn't notice 2°. But theoretically it could make a difference, because it is added coolant flow that bypasses the t-stat.
I also think your t-stat is a bit on the tired side. You could use a few more degrees of running temp. Not a big deal yet, but keep an eye on it.
johnsonjf
06-18-2018 03:51 PM
joejackF250
05-17-2016 04:05 PM
ROBBINthaHOOD
11-11-2014 07:26 PM
Metalhead47
01-07-2014 11:00 PM
speedtrapp
10-10-2012 08:24 AM
Quick Reply: Deltas after adding coolant filter
