Short term storage/parked
Old Jan 29, 2013 | 11:05 PM
Yahiko's Avatar
Yahiko
I got my back surgery reset for Feb 12. I won't be driving for about 3~4 weeks.
Being the PNW and all the rain I was thinking of filling the tank up and putting
a trickle charger on the truck and parking it.
Think I have it covered?
Sean
Old Jan 29, 2013 | 11:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Sounds good to me.
Hope the surgery goes well. What exactly are you having done?
Josh
Old Jan 30, 2013 | 02:45 AM
Yahiko's Avatar
Yahiko
I have two disks that need to be cleaned up. It's called microdiscectomy. Look it up on Youtube.
I know I won't again. Anyway they are working on L4 L5 S1. I fell at a job and blew out the disks
and have had back and leg pain. Really makes it hard to work on equipment for a living.
Dr said I would need a babysitter for a few weeks NO lifting and bending.
Sean
Old Jan 30, 2013 | 05:35 AM
dannyboy950's Avatar
dannyboy950
I wish you well with yer surgery. Do not rush going back to work that old iron will still be there. Give yer self time to heal.
Old Jan 30, 2013 | 08:45 AM
69cj's Avatar
69cj
I had the L5-S1 disc removed in 1989, Best thing I could have done considering. It's been good ever since. If I do something dumb like being over a fender all day a couple of Advil at bedtime and I'm good to go the next morning. I was back at work in three weeks with a 5 lb. weight limit that was increased by 5 lbs. every month. Once again, good luck Sean and keep us in the loop.
Old Jan 30, 2013 | 09:41 AM
mhoefer's Avatar
mhoefer
Fuel conditioner in the fill up, drain ficm just in case, if the oil is close to needing a change I would Change that. Put the trickle charger on a timer for only 4 hours a day.
Old Jan 30, 2013 | 10:21 AM
Bullitt390's Avatar
Bullitt390
Drain the FICM?
We're talking a couple weeks here not a couple years LOL
Maybe my definition is a little different, but short term storage to me would be 3-6 months.
A trickle charger for a couple weeks is all that's needed.
Josh
Old Jan 30, 2013 | 12:13 PM
cartmanea's Avatar
cartmanea
Be sure you use an automatic battery maintainer and not an uncontrolled trickle charger, since those will over-charge in that amount of time.
Old Jan 30, 2013 | 03:55 PM
Yahiko's Avatar
Yahiko
The charger I will be using is one of the smarter ones. You can watch it cycle
on and off. Then it goes to a float charge. The oil change has about 2000 miles
to go. I always put a dose of PM-23 in it. And the last think is will be parked
under the security camera where I can take a quick look at any time.
Because it will have time to sit I may put on a good leather dressing and
that will give it time to really soak in.
On the surgery they are not removing the full disk just the bits that are pressing
on the nerve root for the left side of the 2 joints. They say it will take less that 1 Hr
of surgery to do this.
I'll keep you all posted and NO I won't post any photos
Sean
Old Jan 30, 2013 | 04:37 PM
69cj's Avatar
69cj
Sean
Post your pics and I'll post the ones of my lobotomy.
Flip4ford
Kansas Chapter
May 21, 2009 11:54 AM
FESTER1st
Washington Chapter
Jul 23, 2008 12:21 PM
55 f350
Jun 16, 2008 07:55 AM
SpartanDieselTech
Sep 12, 2007 10:16 AM
RapidRuss
20
Sep 5, 2007 11:27 PM
