Clucth linakge
Old Jan 26, 2013 | 09:10 AM
Lons's Avatar
Lons
Clucth linakge
Hey all,
New here.
I'm finally going to get my truck up and running again after a 10 year hiatus.
One thing that put everything on hold was a broken clutch linkage. I couldn't find it back then and now I'm having issues finding it again.
The truck is a 1974 F100 with 360 FE and 4sp NP435.
The part I'm looking for is the ball end that mounts to the engine for the equalizer bar. I found a few that says its the one but they don't look like the one I remember.
I did say "remember". The ball shattered in to a bunch of little pieces while I was driving down the road. I was able to retrieve some of the parts from the roadway and what was left under the truck. I spent over a month going from junkyard to junkyard looking for this piece but none in the area had it. I was moving at the time so I put the pieces in a box and figured I would get to it after the move. Well, 10 years later I finally got around to it. Now I can't find that box anywhere.
What I remember was it mounted to the back and bottom of the engine and had a steel ball on the end where the equalizer bar slid over.
Thanks
Old Jan 26, 2013 | 09:20 AM
bamaf150's Avatar
bamaf150
Truck Parts and Truck Accessories
Any of this look right?
Old Jan 26, 2013 | 09:27 AM
AK FORD GUY's Avatar
AK FORD GUY
332-428 Ford FE Engine Forum: 390 Mustang clutch pivot engine side mounting question
Clutch Pivot Bracket issue on 390...Please Help!! - Vintage Mustang Forums
I believe both of these threads list what you need. Sounds like you should be abpe to get it from Dennis Carpenter or another vendor of it's kind.
I think mine looks like the one in this pic.
Old Jan 26, 2013 | 11:00 AM
Lons's Avatar
Lons
In the "clutch release comments" section, it looks close to the only item that does not have a number going to it.
The one in the pic looks close also.
What I remember is three bolt holes, 2 on the back 1 one the bottom. Similar to the one for the Mustang in the link above but not as long or squared off.
The one I remember looked close to the one AK Ford Guy has in the pic but the ball end was a ball, steel sphere.
I'll try Dennis Carpenter and see what they have.
Old Jan 26, 2013 | 11:50 AM
mikeo0o0o0's Avatar
mikeo0o0o0
Dennis Carpenter has 3 (704) 786-8139
Bracket assy., engine, clutch release equalizer
Fits 73-76 F100-350, 3 or 4 spd trans w/360-390 engine
C6TZ-7A572-M
Perogie Enterprises, Highstown, NJ has 1 (609) 448-5593
SRBF150
27
Mar 7, 2019 03:32 PM
MeTo
Jun 10, 2018 12:36 PM
Mitch1407
Jun 17, 2011 07:26 AM
navigatorstang
Jan 8, 2011 06:01 PM
prerunner
1983 - 2012 Ranger & B-Series
Oct 25, 2006 10:48 AM
