'97 Limited questions.
Old Jan 21, 2013 | 02:47 AM
Flash635's Avatar
Flash635
I've had an XLT for a few years and have just bought a '97 Limited.
I have a bad back so I can't climb under the car to look properly, does the Limited have self levelling suspension in the back?
The shocks look like airbag types from what I can, the shield is very big, but I can't see any air hoses or any other mechanisms anywhere.
Another thing; on the driver's side arm rest where the mirror controls are there are 3 rectangular shaped holes, it looks like something should be there, the XLT didn't have it.
Old Jan 21, 2013 | 06:51 AM
shorod's Avatar
shorod
Load leveling suspension was an option. I'm not sure if all Limiteds had it, it may have been an option. It sounds like yours has it.
Regarding the 3 rectangular holes, any chance you could post a picture of them? Have you looked on the passenger side controls to see if there is maybe a "Limited" badge or something in that same location that is missing from the driver's side?
-Rod
Old Jan 21, 2013 | 08:17 AM
Flash635's Avatar
Flash635
Thanks Rod.
I take it the load leveling is automatic?
If it's manual maybe the switches go in those rectangular holes?
I'll take a photo of the holes tomorrow, it's dark now and the only camera I have is the phone and it doesn't have a flash.
Old Jan 22, 2013 | 01:53 AM
Flash635's Avatar
Flash635
It's right hand drive.
Old Jan 22, 2013 | 06:59 AM
shorod's Avatar
shorod
Those holes appear to be for a 2-person seat memory. The smaller squares were for the "1" and "2" buttons, and the larger rectangle hole looks like the opening for the "Set" button. I don't know if these buttons are just missing from your truck or if that door panel is from a different Explorer/Mountaineer. You might check your owner's manual to confirm this was for seat memory as well as to understand better the load leveling.
-Rod
Old Jan 22, 2013 | 07:02 AM
shorod's Avatar
shorod
Looks like maybe the switch holder is upside down.
O'Reilly switch for 2003 Explorer
-Rod
Old Jan 22, 2013 | 07:19 AM
Flash635's Avatar
Flash635
Thanks Rod. There's a possibility that switch is inside the door.
At the moment when I use the remote to unlock the door the seat slides all the way forward, which is the exact opposite of where I want it to be.
I've downloaded an owner's manual from the Ford website, I've got a bit of light reading to do.
Old Jan 22, 2013 | 12:40 PM
shorod's Avatar
shorod
That's a good sign that your Explorer has the seat memory feature. The manual will explain how to assign a key fob to a particular memory setting. Of course you need those switches on the door to save your settings to memory....
Good luck, and happy reading!
-Rod
Old Feb 15, 2013 | 01:35 AM
Flash635's Avatar
Flash635
I got the Limited out on the road and turned on the load leveling switch, it keeps cycling even when the ignition is off. I'd say I have a leak somewhere.
amm888
Dec 21, 2005 02:01 AM
djtdaveboy
1983 - 2012 Ranger & B-Series
26
Jun 4, 2004 01:06 PM
brussell
May 14, 2003 07:44 AM
Roy5
Mar 1, 2003 03:51 PM
tankhead
Oct 30, 2002 10:02 AM
