Coolant leak need help
Old Jan 19, 2013 | 10:56 PM
BLADE35's Avatar
BLADE35
Any Luck finding it???????????
Old Jan 20, 2013 | 12:40 AM
04badford's Avatar
04badford
how does your oil look,? get your self a extention mirror and look at the heads also look real close at the block plugs,
Old Jan 20, 2013 | 01:03 AM
daddykitty's Avatar
daddykitty
one of those video cameras on a stick would come in real handy about now
Old Jan 20, 2013 | 11:19 AM
Special Ed's Avatar
Special Ed
LEAK - YouTube
Appreciate all the input. So I wrapped it up late last night. I put new hoses & thermostat when I did the EGR /cooler about a year ago. All parts from Ford. So you know how the OE hoses come with the pinch clamps on them already. When I put the new hoses I could not get the OE clamp off the lower hose at the cover clamp was like imbedded in the rubber so I just used it as it came, all other hoses I double clamped with quality worm clamps. Since it was dripping off the power steering pump that hose was the only thing above it. So after I ripped all the stuff out to finally get in there with a mirror & light I could see wetness. Long story short pulled the hose, removed OE pinch clamp, cleaned hose/cover, installed 2 quality worm clamps, tightened her up, re-assembled the mess, filled her back up, ran her for awhile w/ heater on while I cleaned the wet front end, then pumped her up to 15PSI & had a beer. After the beer i looked under & dry as a bone! Wooooohoooooo!!! Couldn't see anything with everything in the way. Thank u all for your help. Its 10 degrees out & I am warm finally.
Old Jan 20, 2013 | 11:32 AM
69cj's Avatar
69cj
That's the beer kicking in. LOL Congrats.
Old Jan 20, 2013 | 11:47 AM
04badford's Avatar
04badford
Glad you found the problem Ed, I in a slow process of removeing those clamps ,they are real hard to remove with out the tool , I have a plumbers wrench for the worm clamps torxs to the right spec .
Old Jan 20, 2013 | 02:23 PM
Special Ed's Avatar
Special Ed
Thanks Mike & BadFord. I tried a few tools but found the medium size channel locks to fit the best. My neighbor stopped by while i was working & told me they make a tool just for those clamps but I am not aware of it. I will never use those clamps again.
Old Jan 20, 2013 | 02:24 PM
Special Ed's Avatar
Special Ed
For the worm clamps I used a 1/4'' ratchet tight with my "left" hand. Also used quality clamps, not the BS you find in the parts stores that when u tighten them up they pop & break!
Old Jan 21, 2013 | 09:43 AM
Special Ed's Avatar
Special Ed
Guess that tool goes something like this
Bottom-line pricing on Astro Pneumatic - 9409A at ToolTopia.com
Old Jan 21, 2013 | 11:33 PM
04badford's Avatar
04badford
Thanks Ed , yea thats the tool ,but most are changeing to to known worm clamps wide body I have seen some mech work with these and throw them aside because of the handle ratchet so theres good and bad ones , plumbers torx ratchet is what I have in the box.
Old Jan 23, 2013 | 04:07 PM
Special Ed's Avatar
Special Ed
Good luck on changing those clamps out. I like the idea of a "wider clamp", that way i wouldn't have to run 2 of them.
Greenlawnracing
Oct 16, 2015 10:06 AM
cdrmotorsports
21
Nov 3, 2010 06:43 PM
98FordTruck
Jan 15, 2009 06:31 PM
leitrum
Dec 2, 2006 11:50 AM
rickytz7111
Jan 31, 2005 08:15 AM
