1997 7.3 PS - acceleration lag
Old Jan 17, 2013 | 09:14 AM
lrdmora's Avatar
lrdmora
I had something a little strange happen yesterday and today.
I was stopped at an intersection, took my foot off the brake and hit the accelerator, nada, truck was in gear and engaged moving forward very slowly but zero rpm change. Just nothing, then after about 5-10 seconds it hit and the the RPMs went up and away I went. This kept happening at every stop. Between stops it kept at a constant RPM and no issues. It seemed like every time I hit the brake it killed the accelerator and it just stopped working. I confirmed this later on the freeway when someone cut me off and I had to hit the brakes hit the accelerator to go around and nothing.
I've had some strange electrical issues with fuses controlling my shifting etc. So my first thought was that I have a bad accelerator switch/sensor. It's not stalling, it stays idling at a constant so I'm pretty sure it isn't the CAM sensor.
I had it on the back tank and decided to switch it to the front and it stopped, I switched it back to the rear tank and it hasn't done it again but I'm just waiting for the other shoe to drop. Is there a chance that this has something to with the tank switch? I'm having trouble believing it's that easy. Any ideas?
Old Jan 17, 2013 | 09:28 AM
DIYMechanic's Avatar
DIYMechanic
It sounds like your IVS is going bad. There are two devices on the accelerator pedal. On is a throttle position sensor (TPS) that tells the engine computer (PCM) how far you're pushing the pedal down, and the other is an idle validation switch (IVS). If the IVS isn't opening and closing like it should, the PCM will ignore the TPS signal and leave the engine at idle. It could be as simple as an adjustment, but I think you probably need a new IVS. You could install a jumper to test the theory (Bypassing the IVS) but I would only do that as a test and I wouldn't advise leaving it overridden. That switch is the safety that stops the truck from running away if there should ever be a problem with the TPS.
I had a truck at work that did this once and pumping the accelerator would un-stick the switch for a while. You have to let the pedal rise to the top of its stroke, but opening and closing that switch repeatedly may get the contacts to make and solve the problem temporarily.
Old Jan 17, 2013 | 09:37 AM
lrdmora's Avatar
lrdmora
Thanks sir, I'll check that out right away, I appreciate it!
Old Jan 17, 2013 | 09:41 AM
Hussler's Avatar
Hussler
What he said ^^^^^^^
It's your IVS (idle validation switch) on the go peddle. With your foot off the go peddle the IVS is actuated telling the PCM your foot is not on the peddle and to, just idle. If you push on the go peddle and the IVS does not disengage the PCM will ignore the TPS (throttle position sensor) and continue idling. If you look down there you will see a push button type switch, that's the IVS. You can also push the go peddle by hand and hear the switch actuate / De-actuate. They get dirty down there by the floor so just clean it up a bit and the problem will probably go away.
Old Jan 17, 2013 | 09:47 AM
lrdmora's Avatar
lrdmora
Awesome, thanks guys. Just in case I have to pick one up who would have one online?
Old Jan 17, 2013 | 10:17 AM
DIYMechanic
If i recall correctly Ford has discontinued the part, but this one is reported to fit the bill as a direct replacement. Get it while you can, the quantity is limited.
SS22BW32-330Y CUTLER HAMMER/EATON | Buy SS22BW32 330Y | Onlinecomponents.com
Old Jan 17, 2013 | 11:12 AM
fordpride's Avatar
fordpride
Spray the ivs with contact cleaner and blow it out
Old Jan 17, 2013 | 01:31 PM
lrdmora's Avatar
lrdmora
My thanks to everyone for the quick responses! This is the place to go for sure!
GR8RN
Jan 17, 2018 06:06 PM
Furr308
Jan 3, 2016 04:43 PM
plgebbia
22
Jul 12, 2013 10:54 AM
PowerstrokeRyan
Nov 18, 2011 03:48 PM
gasco
Feb 27, 2004 08:07 AM
