Pedal Fix?
Old Nov 18, 2011 | 02:21 PM
PowerstrokeRyan's Avatar
PowerstrokeRyan
Pedal Fix?
Must I do the pedal fix that is posted in the mods thread if my throttle doesnt respond until pushing in about a half inch then hearing a click?? Or is that normal for these trucks? My grandfathers 99 7.3 is like a carb motor and responds right away. Thanks in advance.
Old Nov 18, 2011 | 02:33 PM
DIYMechanic's Avatar
DIYMechanic
That is the purpose for the fix. There is a safety switch that has to be broken before the PCM will follow the input from the throttle pedal. That "click" you hear is that safety switch. The goal is to have the switch "click" as soon as the pedal moves so the throttle application isn't delayed or interrupted by the safety switch.
Old Nov 18, 2011 | 03:26 PM
PowerstrokeRyan
is there anything wrong with not having the safety switch activate right away?
Old Nov 18, 2011 | 03:48 PM
DIYMechanic
No, it just makes the throttle "jumpy" if it doesn't open the safety switch before the throttle starts to register a position. An example would be if the pedal goes to 15% before the switch clicks, then you don't get the 0-15% range on the throttle and it just makes it a little more jumpy.
Robert Frazier88
Apr 22, 2021 10:51 AM
MustangMatt96GT
Oct 13, 2009 10:53 AM
THEDON117
Jul 13, 2009 05:22 PM
dieselstroke
Dec 2, 2004 08:44 PM
Captdave55
Sep 30, 2004 10:29 AM
