97 Powerstroke questions
Old Dec 29, 2015 | 08:03 PM
Furr308's Avatar
Furr308
Hey guys, I just traded my bronco for a 97 f250psd. So I have some questions, as I have no experience with these trucks. When I go to hit the throttle, there is a "dead zone" for about an inch or so before the engine responds. If you let off the throttle in any gear, it wont hold speed and decelerate smoothly like it should, and if you try to go low speed/rpm in that "dead zone" it lurches, but it idles along fine. It just doesnt like going slow, which makes going down my driveway a bear . Does anyone know what that could be? Throttle position sensor or something?
Old Dec 29, 2015 | 08:16 PM
z31freakify's Avatar
z31freakify
Sounds like the APS(accelerator position sensor, the one on the pedal) they tend to go bad.
Welcome to the OBS brethren
Old Dec 29, 2015 | 08:43 PM
Furr308's Avatar
Furr308
Thanks for the welcome and the info. Do I need to replace the whole sensor and pedal assembly, or can the sensor be separated from the pedal and be replaced separately?
Old Dec 30, 2015 | 11:49 AM
madpogue's Avatar
madpogue
More likely it's the idle switch. Also on the pedal. If it's not adjusted right, the engine doesn't rise off idle until you've put a fair amount of movement into the pedal. The PCM then responds to that pedal position rather abruptly. The key is to adjust the idle switch so it closes with the least amount of pedal movement possible. There's a bit of wiggle room with the mounting holes, but some folks just bend the tab that engages the switch. Don't overadjust, or the switch will always be closed, and the PCM will never detect the "open-to-closed" sequence and will never take the engine off idle.
Old Jan 3, 2016 | 04:43 PM
Talyn's Avatar
Talyn
All these trucks come with a small dead zone at the start of the throttle.
That's why there is a "hot foot mod"
TJBeggs has a post on it someplace.
It's basically to give the idle sensor time to disengage before the TPS sends fuel signals.
SLAMMIN 22
15
Feb 13, 2011 07:02 PM
crewsd
Feb 16, 2008 07:36 PM
Paul1212
Dec 6, 2006 05:58 PM
dieselstroke
Jan 16, 2005 07:47 PM
dieselstroke
Dec 2, 2004 08:44 PM
