Problem with my excursion
Old Jan 12, 2013 | 05:28 PM
ccllud's Avatar
ccllud
So I bought a 02 excursion 4x4 with the V10 and just drove it 6 hours pulling a car trailer with a car on it no problems. Once on a steep hill my ABS light flashed but that's it. I stopped multiple times with no problems.
Got to Lubbock and unloaded the car off the trailer and drove the excursion and empty trailer around the block.
Came out an our later and my check engine light is on (weird kind of square light bottom left of gauges)
It will idle fine but if I shift it into gear after a few feet of driving it dies and the battery light comes on and the overdrive off light flashes.
Any ideas?
Old Jan 12, 2013 | 06:41 PM
rla2005's Avatar
rla2005
Check for codes. The computer (PCM) is trying to tell you what it thinks is wrong.
Old Jan 12, 2013 | 06:46 PM
ccllud's Avatar
ccllud
Where can I get a code reader? Or can you rent them? (as I can't drive)
Old Jan 12, 2013 | 06:48 PM
Tom's Avatar
Tom
Not good...
The battery light is normal, that's on because the engine isn't spinning the alternator anymore. The O/D off light is not...that means that the PCM has detected something wrong with the transmission.
Hopefully it's something simple, but the truck needs to be scanned with a capable scan tool for us to give you much more advice. Basic scan tools will not be able to read a transmission code.
www.autoenginuity.com is the one many of us use.
Old Jan 12, 2013 | 07:03 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
You can probably take it to most auto parts stores and they have one they'll come out and read it for you for free. It won't be nearly as detailed at AE, but it'll give you a good idea. Take the code number (if they don't tell you what the problem is) and google it.
cjben
Nov 27, 2009 04:04 PM
fordinmudd
Aug 10, 2005 03:32 AM
ibew481
Oct 18, 2004 09:10 PM
ipkyss
Nov 4, 2003 06:13 PM
cmoscar
Sep 5, 2003 02:10 AM
