OD light flashing code P0743
Old Sep 3, 2003 | 06:46 PM
cmoscar's Avatar
cmoscar
Question OD light flashing code P0743
I have an Explorer '96 4.0 which recently started flashing the O/D light and the Check Engine light is on.
The code on the computer is 0743 (Torque Converter Clutch Circuit Electrical). The Trip counter and Odometer are working intermittently since the light came on but the Speedometer works fine. The transmission shifts perfectly and I have traveled about 300 miles since the problem started.
The car has had a turbine like noise comming from the Mass
Airflow sensor for a long time now, even before this light came on.
I had the oil in the tranmission changed to see if the failure goes away but no change yet.
Can someone advice?
-Thanks
Old Sep 3, 2003 | 11:40 PM
aptgrk's Avatar
aptgrk
This turbine noise, does it happen when the truck is at idle, and when it is warm? If so, you have to change Idle Air Control Valve, just had that done on my explorer, fixed the problem. Its located behind the throttle body on right side of the intake manifold, easy removal of 2 bolts.
Old Sep 4, 2003 | 06:25 PM
cmoscar's Avatar
cmoscar
I am not sure that it only happens in IDLE. I will test the valve to see if it fixes the failure.
Thanks....
I am still very worried about the O/D light flashing. If someone replies about this I would greatly appreciate it.
Old Sep 5, 2003 | 02:10 AM
marragtop's Avatar
marragtop
There are many posts on the flashing OD light. I suggest you do a search on 'Flashing O/D light'. Does the transmission seem to shift a bit harder now that the light has come on? If so, then the trans is in 'cripple mode', and it's not good to drive it an extended period of time that way. You might want to disconnect the battery for 5 minutes(this will reset the codes), and then reconnect. See if the light comes back on. I've had this problem on my '95 a couple of times and resetting it keeps the light off for months. However, when my light comes on, pulling the codes doesn't reveal anything. So your case may be different since you are getting codes.
Mike
Jkincella26
Jul 12, 2016 06:36 AM
TrippyDaze
Modular V8 (4.6L, 5.4L)
Jun 22, 2016 06:21 AM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
desertdogs
Nov 12, 2008 07:58 PM
Lushman
Nov 7, 2006 09:34 AM
