Spark plug?
Old Jan 12, 2013 | 06:51 PM
F350-6's Avatar
F350-6
Spark plug?
OK, this technically isn't for the Ex (since it's a diesel), but I do need to replace the spark plugs in a Ford V8 soon. Problem is I've been running diesels for a long time and haven't really kept up with spark plugs.
Seems like there's lots to choose from now. Regular old fashioned, double tip, triple tip, platinum, kryptonite, thermo-nuclear tip, etc. Is one spark plug really any better than another, or is it all just marketing gimmicks? Is it worth spending extra for some fancy sounding spark plug?
Old Jan 12, 2013 | 07:54 PM
gr8scott72's Avatar
gr8scott72
Just stick with the tried and true Motorcraft platinum plugs.
Old Jan 12, 2013 | 08:06 PM
Stewart_H's Avatar
Stewart_H
Chris, it matters what engine the plugs are for.
What year is the vehicle and what engine?
Stewart
Old Jan 12, 2013 | 08:18 PM
F350-6's Avatar
F350-6
Stewart
2005 4.6L
Old Jan 12, 2013 | 08:33 PM
Stewart_H's Avatar
Stewart_H
2005 4.6L
Ok, it's not the 3V engine then.
The 3V engines use a two-piece plug that has a tendency to break.
For the 2V engines, Motorcraft and NGK plugs in the proper heat range were popular choices for the 5.4L Lightning owners.
It's probably a stock setup, no power-adder, correct?
Stewart
Old Jan 12, 2013 | 08:45 PM
F350-6's Avatar
F350-6
I haven't really dug into it, but I do believe it is a 3v Stewart. It's a pony engine. I thought they were aluminum block, 3v, with 300 hp.
Edit: And I've got access to the tool kit designed to remove the broken lower portion of the spark plug assuming it's the same kit as the 5.4 plugs that broke all the time.
Old Jan 12, 2013 | 09:17 PM
Stewart_H's Avatar
Stewart_H
Sorry Chris, my brain was thinking strictly truck engines.
Stewart
msasteeler
6.2L V8
13
Nov 27, 2019 09:42 AM
TexasLonghorn75
2004 - 2008 F150
Nov 26, 2013 12:18 AM
garysorenson
31
Jul 19, 2008 11:23 PM
scottie2hottie
General Automotive Discussion
Dec 21, 2006 07:52 PM
