Isspro dimming issues
Old Feb 18, 2013 | 07:16 PM
  #46
4BigGreen's Avatar
4BigGreen
Originally Posted by jsm180
So are you pulling the switched 12v from the brown parking light wire? I'm having the same problem with flickering lights. Mine work just like the OP's video.
jsm180, Yes, I tapped into the dark brown wire on the light switch as my power source for the led dimmer.
The problem for me was that I used the Autometer Ford matched gauges for my A-Piller Pod and I used Isspro Ev2 Gauges on my Triple underdash pod.
The EV2's were too bright for me so I either needed to dim them or wear sun glasses. Besides I was like a lit fish bowl driving down the road at night.
I wouldn't have needed a dimmer for the Autometer Ford matched gauges as they were the same brightness as my dash lighting.
Old Feb 18, 2013 | 07:22 PM
  #47
4BigGreen's Avatar
4BigGreen
Shoot, I didn't read the question correctly.
jsm180, I used the Light-blue/Pink trace wire off the steering column for the key-switched gauge power source.
Then I used the dark brown wire on the light switch for the gauge lighting source.
Sorry for the confusion.
Old Feb 18, 2013 | 07:41 PM
  #48
jsm180's Avatar
jsm180
Thanks, I tried that and it didn't help the flicker. I've got the programmer coming but was hoping for a simple quick fix. Isspro confirmed what the earlier poster said about the auto headlights causing the problem.
Old May 31, 2014 | 07:34 AM
  #49
schlepprock250's Avatar
schlepprock250
Ok I've been searching hence the old thread. Are the Isspro EV2s THAT much brighter at night than say Autometers? Do you HAVE to have a second dimmer for them? I'm just getting around to installing my Isspros, can I just wire them straight to the oem dimmer?
Old May 31, 2014 | 08:40 AM
  #50
jeffreyt's Avatar
jeffreyt
They won't blind you if they are kept bright, they will just flicker if you try to dim them when you wire them that way. I always said I was going to adjust the wiring so I could turn them down, but they haven't bothered me at all.
Old May 31, 2014 | 08:47 AM
  #51
schlepprock250
Thanks Jeff. So you just have them straight wired so they come on with the light switch?
Old May 31, 2014 | 09:42 AM
  #52
jeffreyt's Avatar
jeffreyt
The main power comes on with the key. The lights are wired through the truck dimmer, then through the isspro dimmer. I remember a blue wire with pink trace in there somewhere, but I'm not 100% sure that was the dimmer. I know main power I used an add-a-fuse in the fuse box. I'll check, but it may be previously spelled out in this thread.
Old May 31, 2014 | 09:46 AM
  #53
jeffreyt's Avatar
jeffreyt
Very first post shows me tapping into the blue/pink wire behind the dimmer. Man, what a memory lol
Old May 31, 2014 | 11:02 AM
  #54
schlepprock250
Isspro dimmer?? All I have is the guages, is the Isspro dimmer something I need before starting the install? That's kinda what I was asking, if they were too bright to run just by tapping into the head light harness using standard brightness.
Old May 31, 2014 | 11:20 AM
  #55
jeffreyt's Avatar
jeffreyt
It's not necessary, you can install through the factory dimmer. It will likely cause a flickering issue when you dim down below a certain point.
If you do get the isspro dimmer, you don't want to wire it through the factory dimmer like I did. All it is is a potentiometer
ScottyC50
Aug 20, 2018 08:37 PM
PapaGeek
General Automotive Discussion
Jul 2, 2016 06:14 AM
marty277
Mar 21, 2013 09:11 AM
Krisx125
Oct 8, 2010 11:13 PM
Daniel2986
1983 - 2012 Ranger & B-Series
18
Jul 4, 2006 02:48 AM
