brakes...
Old May 31, 2014 | 12:39 PM
bcaughhorn's Avatar
bcaughhorn
brakes...
I just put a new steering gear box and power steering pump in my truck. I filled it and drove around the block maybe 4 miles. the no slack in the steering is awesome but when I hit the brakes the pedal is a lot softer and goes down more almost like I need to bleed them but I haven't opened them up lately.
the pedal will go down then push back a little and that's when the brakes grab.
what do I need to do???
Old May 31, 2014 | 01:05 PM
hydro man 17's Avatar
hydro man 17
Sounds like you have air in the hydroboost system. Did you bleed the hydroboost system when you replaced the power steering pump? If not that is most likely your problem.
Old May 31, 2014 | 01:19 PM
bcaughhorn's Avatar
bcaughhorn
No I didn't. Guess I'll have to look that up when I get home
Old May 31, 2014 | 03:25 PM
hydro man 17
There is a current thread with a full write-up on it, should be all you need.
Obs7.3Powerstroker
Jan 15, 2019 09:57 PM
tbirdage
Sep 9, 2010 11:06 AM
texasjack
26
Jul 27, 2008 07:52 PM
paulford
Aug 9, 2006 01:01 AM
mudcat12
Feb 27, 2004 05:30 AM
