Auto 4x4 issue
Old Jan 10, 2013 | 03:58 PM
id_birdhntr's Avatar
id_birdhntr
Auto 4x4 issue
My auto 4x4 high does not seem to be engaging on my 01 F250 but when I try 4x4 low it works. Any ideas? I was told that there is some sort of speed sensor that may be bad but not sure where to start looking. Any help is appreciated.
Old Jan 10, 2013 | 04:13 PM
AzPete's Avatar
AzPete
First of all...check to see if power is getting to the shift motor when 4 wheel high is selected.
Old Jan 10, 2013 | 04:28 PM
id_birdhntr
Without the engine running I can hear it "switching" when I turn it to 4x4 high and low. It will engage to 4x4 low but not 4x4 high. I figured this would eliminate a vacuum issue??
Old Jan 10, 2013 | 04:48 PM
AzPete's Avatar
AzPete
Shift motor is electric....hubs use vacuum to engage and disengage.
How have you verified that high range is not engaging?
Old Jan 10, 2013 | 05:07 PM
01PS's Avatar
01PS
I think you may be assuming 4 low is working because of the gear change. Your hubs are probably not working at all and you have 2X4 in low range. Switch to 4 low and try turning the half shafts by hand. If they spin free you have a hub issue. If they don't spin, try the same thing in 4 high and see what happens.
Old Jan 10, 2013 | 05:24 PM
id_birdhntr
We've had snow covered roads all week which is why I've noticed this. 4x4 low does work for sure and it's not just the gear change. When I get out and turn the hubs to manual, 4x4 high works so I know it's getting power to the front. Shifting from neutral, reverse and back into drive seems to get 4x4 high to work briefly but always disengages after a short period. I will check the shafts tonight when I get home to double check. You would think it's a hub/vacuum issue but since it works in 4x4 low I'm at a loss. My vents all work fine as well.
Old Jan 10, 2013 | 05:29 PM
AzPete's Avatar
AzPete
May be an issue with dried and hardened grease in the hubs. My 2000 had not been used much before I got it and now, with use, it us staying engaged better. The grease may be stopping yours from fully engaging in auto but the manual position forces it to engage.
Old Jan 10, 2013 | 05:40 PM
id_birdhntr
Thanks. How bad is it to leave the hubs in manual for a few days?
Old Jan 10, 2013 | 06:09 PM
AzPete's Avatar
AzPete
Not an issue as long as you have 2 wheel drive selected inside. Fuel mileage may suffer just a bit is all.
Old Jan 11, 2013 | 03:33 PM
id_birdhntr
After playing around a little bit on my street I noticed even 4x4 low disengages at a higher RPM. Has anyone ever heard of a speed sensor on the TC that may go bad?
Old Jan 11, 2013 | 08:00 PM
AzPete's Avatar
AzPete
Four wheel drive does not disengage until you select a different option inside. Still sounds like your hubs need work. Also....Don' t use 4 wheel drive on hard dry pavement....it could cause issues.
robinsonpowerstroke
13
Mar 14, 2008 05:33 AM
Raymond Bourque
Dec 8, 2005 08:39 PM
rarekoncepts
2004 - 2008 F150
Nov 20, 2005 10:38 PM
pbuzz3323
Feb 29, 2004 11:33 AM
mptruck
1997 - 2003 F150
Apr 1, 2002 08:54 AM
