Headlight issue
Old Jan 11, 2013 | 02:33 PM
th67ss's Avatar
th67ss
Headlight issue
My low beam have not been coming on when my tilt is up, but when I pull it down they will light. The high beams work and parking/fogs work with the tilt wheel in the up position. I normally keep my switch in the auto position but have also tried it in the manual and get the same.
I'm planning on checking the grounds, but I really think its a wire running to the low/high beam lever on the column. Would anyone know which/what color the wire is for the low beam side of the lever?
Old Jan 11, 2013 | 03:11 PM
garydmundy's Avatar
garydmundy
headlight issue
In my 2002 f350 4x4 the low beam wire is dark blue/orange and the high beam wire is grey/orange. Hopes this helps.
PS: It is 2:00 in the afternoon and it is 5 degrees below zero and the wind is blowing like he^^^^. Welcome to Banner Wyoming!
Old Jan 11, 2013 | 03:56 PM
BillyBob69's Avatar
BillyBob69
Remove the cover from the top of the steering column and I bet you will find the offending wire. It is a known issue that with alot of tilt wheel use, there are a couple of wires that will pull and rub and eventually break. Just cut the bad spot out and add a couple of inches of wire and you will be good to go.
Old Jan 11, 2013 | 08:19 PM
th67ss's Avatar
th67ss
Thanks for the info guy's! It's going to be in the 60 here tomorrow so I figure I'd try and fix it before the temp drops again.
lowlander
2015 - 2020 F150
Sep 21, 2016 08:18 PM
dajo
1997 - 2003 F150
Jan 28, 2015 10:49 AM
90pioneer
Apr 21, 2013 05:57 AM
xxshine
Jan 26, 2012 08:16 AM
aurgathor
1978 - 1996 Big Bronco
Apr 25, 2007 08:03 PM
