Where to buy a 12V 3/8 shutoff valve for RDS AUX tank?
I currently have a RDS 91 gal aux tank and currently use it as the gravity feed system. However I HATE the gravity feed, sometimes it takes 2 days to fill up my tank!!! I want to add a fuel pump and 12V shutoff valve so I can control everything from in the truck while driving. Problem is the RDS drain valve is a 3/8 female connection and I cannot find any 12V 3/8 shut off vales! does anyone know were I can find any? or if anyone has a similar setup, what have you used?
Thanks!
Thanks!
12 Volt Fuel Valves but the only one they make in a 3/8 is an odd shape and i do not think it will sit flat since the drain hole is very very close the touching the floor already.
This looks promising:
2-Way Zero Pressure Solenoid Valve [2W16010N] | DudaDiesel Biodiesel Supplies
More possibilities here:
Process Valves, Water Solenoid Valve, Steam Valve, Diaphragm valve
Thank you! the first one looks good. But is it 12V? I actually just decided to check on amazon, and I actually came up with this one 3/8" Electric Solenoid Valve 12-VDC Air, Gas, Fuel Normally Closed: Amazon.com: Industrial & Scientific I think with a 3/8" male to male coupling it should work
EKTMS,
I have a 60 gal RDS gravity feed, and it runs all the time, thus keeping my tank topped off. Are you just opening the feed valve when your main tank is near empty? I don't have much problem keeping my main tank full, except when towing heavy, it will use faster than the fill--but it catches up overnight. Do you have the RDS gravity fill check valve installed?
Joe
Joe
EKTMS,
Joe
Joe
Andrew010
6.7L Power Stroke Diesel
26
06-28-2016 06:16 PM
F250Dave
17
09-12-2005 11:12 PM
