A multitude of problems..
Old Mar 17, 2013 | 04:19 PM
  #31
Tugly's Avatar
Tugly
If you have single-shots with stock nozzles, I've read about many members doing it, but the idle is just a bit choppy. It will be good enough to get some AE data. If you have bigger nozzles, I'd seek input from those who have tried it.
Old Mar 17, 2013 | 06:47 PM
  #32
jetdoc's Avatar
jetdoc
Nope...stock single shots. I'll have to wait a couple of days to do it though. weather is supposed to go downhill. I'm not working in the rain unless I absolutly have to!
Old May 31, 2013 | 11:53 AM
  #33
jetdoc's Avatar
jetdoc
Originally Posted by Tugly
Nope. You have a low IPR signal, the ICP is doing what it's told. If you have 100% nozzles, you might see over 9% IPR, but stock nozzles will have an IPR over 10%. If you had an internal oil leak, the IPR would climb until it the ICP reached the target pressure. This looks like tuning to me.
Bingo...I pulled the valve covers. No oil leaks anywhere. Put it all back together and pulled the chip. Voila! problem solved.
DP is closed on Friday....Just my luck.
Old Jun 4, 2013 | 11:47 AM
  #34
jetdoc's Avatar
jetdoc
BUYER BEWARE!
Needless to say I have to put this POS chip back into my truck. My daughters 12k tuition bill is fast approaching and that takes precedence over a 13yo truck. I will only offer this little tidbit of advice:
If you switch over to Single Shot injectors, make sure you pick a tuner who knows what they are doing.
Enough said.
Duncan
Fordenthusiasts
May 10, 2016 10:28 PM
justinlb917
Jul 27, 2015 01:05 PM
Tormz
13
May 5, 2015 11:17 PM
flightnurseln8
27
Jun 9, 2008 12:23 PM
SrqScion
15
Oct 7, 2007 09:28 PM
