A multitude of problems..
Old Jan 8, 2013 | 07:49 AM
jetdoc's Avatar
jetdoc
Last year I changed (all at one time) the following parts:
Turbo- 38R
uppipes
Non Epbv pedastal
glow plugs/relay
UVC harnesses
Injectors-Reman single shots
Regulated return.
IPR
After a year of driving I'm having a problem that is progressively getting worse. On cold start, HPOP pressure 400-600 psi(I have a guage) however once the oil temp comes up it will barely idle in stock tune and I must switch to either my tow tune or 80E to make it idle. On top of that it just has no power off idle. With an empty truck I must give it a little fuel when I release the clutch something I never had to do even on a hill with the stock set up. The other problem I have is high EGT when towing on hills. I'm thinking I have injector o ring issues or maybe a bad injector itself. I do not have AE(funding issues at the moment) but is there any other way to isolate what the problem could be? Thanks in advance!
Duncan
Old Jan 8, 2013 | 08:09 AM
clux's Avatar
clux
Start the engine with you valve covers off and check your injector spouts for one with a stuck valve that is continuously bleeding oil.
Old Jan 8, 2013 | 08:37 AM
jetdoc's Avatar
jetdoc
Would the stuck valve cause high EGT's?
Old Jan 8, 2013 | 08:47 AM
Tugly's Avatar
Tugly
Low ICP can cause everything you describe... and it is the easiest to test without AE. Pull the connector to your ICP sensor and see how that plays out with idle.
clux's Avatar
clux
Possibly if you've got low oil pressure and not getting good fuel atomization.
Old Jan 8, 2013 | 09:47 AM
Texas Chain Ring's Avatar
Texas Chain Ring
Can I ask what is a good ICP and when can it be considered low? Thanks.
Old Mar 15, 2013 | 05:19 PM
jetdoc's Avatar
jetdoc
Finally ordered the AE and hooked it up today. I found these codes:
Buzz test
P1271 High to low side open cyl 1
P1272 '' cyl 2
P1274 '' cyl 4
P1282 Excessive ICP
KOEO
P1316 Injector circuit /IDM codes detected
P0475 Exhaust back pressure
P0470
KOER
P0269 Cylinder 3 Contribution/Balance fault
P0284 Cylinder 8/ Contribution/Balance fault
Old Mar 15, 2013 | 09:14 PM
Tugly's Avatar
Tugly
Buzz test
P1272 '' cyl 2
P1274 '' cyl 4
This is likely a "hangover" from before your UVCH replacement, but it could be an issue with the 42-pin connector or the VC gasket.
P1282 Excessive ICP
Long story, but: Weak HPOP can do this, tune can do this, UVCH can do this, ICP or IPR can do this, or it could just be a "stale" code. Have you cleared the old codes and started fresh?
KOEO
P0470
EBP cleaned? IDM details in your first list - UVCH
KOER
If you have a gray CPS, ignore this for now. Mine was cured with a CPS from Clay.
Old Mar 15, 2013 | 09:18 PM
Tugly's Avatar
Tugly
470-500 is stock idle, and 2800-2900 is hair on fire.
Old Mar 15, 2013 | 09:20 PM
jetdoc's Avatar
jetdoc
Thanks for responding...No...I literally took it out of the envelope, had some trouble loading it on my daughters netbook(had to charge the battery of said netbook). I will have more time to mess with in the am. I replaced the UVCH and gaskets with new IH units. Does the 50 cent mod still have to be done with the new stuff?
jetdoc's Avatar
jetdoc
my EBP is disconnected...
Old Mar 15, 2013 | 09:26 PM
jetdoc's Avatar
jetdoc
I was driving the other day, engine not fully warmed up, and every time I would add throttle the SES would light. This happened a few times and eventually it started running that total crap. Looked down saw that my F5 display was blank, I was running on the stock tune at the point. Found a safe spot to pull over, shut the truck off and restarted and all was well from there on. Pulled the trigger that day on the AE.
Old Mar 16, 2013 | 05:22 AM
Tugly's Avatar
Tugly
Nope, you're good. With your other answers, we're not going to catch what happened the other day because of the backlog of old codes. You'll need to clear all the codes (using the procedure I set up in the AE class [LINK]), then if that little bugger shows up again... you own his ***.
You can always run a fresh buzz, KOEO, KOER, and data-log a short drive. You want to have a baseline, so if something happens... you have this information to compare with.
Old Mar 16, 2013 | 06:29 AM
jetdoc's Avatar
jetdoc
Ok... Thanks for that. I'll clear the codes, run the tests again and post my findings. Thanks again!
Duncan
Old Mar 16, 2013 | 10:06 AM
jetdoc's Avatar
jetdoc
Cleared the codes this am. Performed buzz test on cold engine. No faults found. Started truck, idle smoother, seems to run better. All good, no return of codes except for the EBP ones. However, it is still doing the original problem.
For your viewing pleasure:
