6.0L scenario
Old Jan 7, 2013 | 01:56 PM
brandon.edwards's Avatar
brandon.edwards
6.0L scenario
So powerstrokers, I have an issue. I know I have a bad injector or two but this is the story. I drive my truck anywhere, let it get to operating temperature and try to start it up and it will not fire it will idle for a second or two, and shut off. If i let it get cold it will fire right up. One of my friends joked that it has a cold starter in it Is there even such thing? Is it possible my injectors have anything to do with this issue?
Old Jan 7, 2013 | 02:03 PM
tiredlr's Avatar
tiredlr
[quote=brandon.edwards;12686286]So powerstrokers, I have an issue. I know I have a bad injector or two but this is the story. I drive my truck anywhere, let it get to operating temperature and try to start it up and it will not fire it will idle for a second or two, and shut off. If i let it get cold it will fire right up. One of my friends joked that it has a cold starter in it Is there even such thing? Is it possible my injectors have anything to do with this issue?[/quote}
Sounds like your FICM is going bad. There are posts in the Tech Folder as how to test it, plus alot of real knowledgable guys here on the forum, that I'm sure will chime in with some great advise.
Old Jan 7, 2013 | 04:12 PM
npccpartsman's Avatar
npccpartsman
Get the truck code scanned, check the tech folder for the FICM test procedure, and report your findings back here.
Old Jan 7, 2013 | 04:46 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Brandon...do you have the Scan Gauge II? That thing is a MUST-ONE in the 6.0 diesels! It lets you see the numbers from just about ANY of the Ford sensors.... Oil Temp/REAL coolant temp and a bunch of others. All except fuel PSI and EGT. It even has a basic code scanner.
Old Jan 7, 2013 | 04:51 PM
run6.0run's Avatar
run6.0run
When you say it idles for a sec or 2, does it start like normal, then die? Or do you have to crank on it to get it to fire? Are you familiar with the stc fitting? Just throwing ideas.
Old Jan 7, 2013 | 05:06 PM
brandon.edwards
Scangauge is my next purchase!! It cranks for a sec. If i have it plugged in a couple hours, it starts like it should. Sometimes even when its not plugged in, it fires like it should. So im taking it to the diesel shop this week an having it diag. So i will post back here and let you know what i find.
Old Jan 7, 2013 | 05:51 PM
npccpartsman
A scangaugeII is OK for gauges in an 04 but it won't read codes. You need something to code scan your truck also.
Old Jan 7, 2013 | 05:54 PM
brandon.edwards
What would recommend?
Old Jan 7, 2013 | 06:51 PM
cheezit's Avatar
cheezit
high pressure oil leak is my guess
Old Jan 8, 2013 | 01:18 PM
tex25025's Avatar
tex25025
AutoEnginuity would be what I would recommend for scanning ability. Best bang for your buck in my opinion.
Old Jan 8, 2013 | 01:25 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
DashBoss is very good at reading codes.
Sounds more like an HPOP issue than ficm
Josh
Old Jan 8, 2013 | 01:28 PM
RideDiesel88's Avatar
RideDiesel88
Sounds like a HPOP problem. Oil seals different when cold and when hot. Switch dummy plugs and switch to stc fitting
abowman
Feb 22, 2024 02:35 PM
Geeha
Sep 1, 2018 02:15 AM
big-head
Jan 6, 2016 05:26 PM
blueline970
Jun 5, 2015 07:24 PM
FMC
Apr 19, 2011 02:35 PM
