Injector?
Old Jun 3, 2015 | 08:59 PM
blueline970's Avatar
blueline970
Injector?
I have a 2004 F250 early build over 260K miles on it. After taking a trip out west Texas and back I noticed my truck starts to jerk a lot around the 50 to 60 mph range under moderate throttle. Getting a contribution code on #6. FICM voltage stays over 47v during KOEO and startup. Took an inferred thermometer and even after truck is at operating temp #6 is reading about 3 degrees cooler then the others. When cranking the engine everything sounds smooth but startups are getting harder. Usually let it idle for a few minutes before taking off on cold start but I am having to let it warm up longer before I can get any power. Did a bubble test and passed and oil level hasnt changed. Fuel mileage has been sucking bad also. Safe to assume the injector is shot and needs replaced? Use Delo 5W-40 Syn every change with motorcraft filters.
Old Jun 4, 2015 | 09:32 PM
blueline970
Anyone?.......
Old Jun 4, 2015 | 10:49 PM
78fordman's Avatar
78fordman
Injector?
replace #6 injector, it will cure your issues.
Old Jun 5, 2015 | 07:07 PM
blueline970
Figured but thought I would throw it out there and see what others thought.
Old Jun 5, 2015 | 07:24 PM
Utah Jake's Avatar
Utah Jake
I fought biting the bullet and replacing my #4 for two years. Spent a whole lot on Hot Shots, Seafoam, Arch Oil, and T6 oil changes mean time. Put a dumb $250 rebuild injector from O'Reilly in today......what the heck took me so long? Love my truck again...enough to wax it!
abowman
Feb 22, 2024 02:35 PM
MSBSouth
Mar 13, 2019 07:03 PM
Fordrocks689
Dec 21, 2018 03:40 PM
Bullitt390
Dec 31, 2015 09:19 PM
PhilnMarilyn
Aug 18, 2010 07:14 PM
