Pull a Steering Wheel
Old Jan 7, 2013 | 11:32 AM
land yacht's Avatar
land yacht
Hello - has anyone on here pulled the steering wheel off, mine is a 2003, without using a steeering wheel puller? It looks like a big torx screw holds it on the column spindle, and maybe a whack with a hammer would move it??
I just got my new rosewood and leather wheel - very pretty - and want to swap it with my old one.
I need to follow the pulling steps in this thread I think? Any advice???
https://www.ford-trucks.com/forums/1...xs-how-to.html
Old Jan 7, 2013 | 05:02 PM
Sunline Fan's Avatar
Sunline Fan
Excursion Fleet Manager
I haven't, and I can tell you, it would be very difficult, especially if it has been on since new. Autozone, etc. may rent you one to use, or you could try to make one up. All you need is three bolts/nuts/big washers and some sort of stiff bar.
Old Jan 7, 2013 | 08:08 PM
land yacht's Avatar
land yacht
So I rented the one at autozone, the ford frame doesn't come with holes to thread the bolts in, so it is a balancing act and a nut and washer required to pop it off. PITA to do and took me 25 more minutes than it should have.
Old Jan 7, 2013 | 10:45 PM
Sunline Fan
I hear you there. I've done it enough times now that I'm quick at it, but it does take some time and more than it should. I actually put a squeeze clamp around the bolts to hold them together/around the frame. Of course the whole thing falls apart and drops down once it pops loose, but it saves a lot of struggling.
Old Jan 8, 2013 | 07:22 AM
land yacht's Avatar
land yacht
that is what I did
Old Jan 8, 2013 | 07:39 AM
DSMMH's Avatar
DSMMH
Pulled mine off in an hour the first time and 20 minutes the second time. Not that hard to do. Troubleshooting a radio control problem. Just be sure the shorting bars for the air bag connectors are in place when you disconnect them. I would assume if the two pins are shorted, it could blow the other air bags. Not sure. Just a SWAG.
DSMMH
highoctane74
Oct 14, 2016 08:47 AM
rocknrod
1997 - 2003 F150
Mar 13, 2014 09:06 PM
zunijoe
Jan 31, 2011 11:07 AM
Witty73
Apr 16, 2010 06:27 AM
sas
Aug 13, 2004 03:08 PM
