1990 steering wheel removal
Old Jan 28, 2011 | 05:25 PM
zunijoe's Avatar
zunijoe
My 1990 4X4 with cruise has a broken ignition lock. I can fix but need help removing the steering wheel without buying a "one-time" tool. I have installed a bar across the steering shaft (with the steering wheel retainer nut installed up) with two 5/16-24 bolts through the bar to the steering wheel. I have it tightened as much as I dare but am resisting the temptation to hammer the middle. Do I need to increase the torque on the two bolts, hammer the middle, or bite the bullet and buy/rent a removal tool?
Old Jan 28, 2011 | 05:40 PM
lew52's Avatar
lew52
You can tap it with a hammer , a steering wheel puller isn't much , the two bolts that go on the wheel just hold the puller , the big bolt screws in to put pressure on the shaft , sometimes they need alot of pressure , then it will pop off....Lew
Old Jan 28, 2011 | 06:01 PM
Kapusta's Avatar
Kapusta
Sometimes those wheels can come off with a good strong yank but it's a good idea to keep the nut on partially so it doesn't come flying off in your face.
Old Jan 28, 2011 | 07:28 PM
Ohio Ford Farm's Avatar
Ohio Ford Farm
I would just get the tool. I think auto zone will rent for free once its all said and done. Should be a small deposit and you will get it back once you return it. or find a buddy close with one I bought a nice kit and have lost one of the bolts already! might find it some day! LOL
if its been on there a while it might take a bit of force to get it to pop lose.
Old Jan 28, 2011 | 09:04 PM
zunijoe's Avatar
zunijoe
That's been my method on previous vehicles...put pressure on the sides and then TAP the center, like removing a flywheel on a lawnmower. My Haynes manual says hitting with a hammer or using a slide hammer will damage the shaft. I don't understand why it would damage the shaft but am hesitant to try. It is dang tempting. It has tilt steering which bothers me as far as hitting with a hammer.
Old Jan 28, 2011 | 09:14 PM
zunijoe's Avatar
zunijoe
I think renting the tool is right but I still think you would have to use a hammer, which is my main question...will the hammer damage the shaft?
As far as renting tools, I rebuilt a 360 for my 73 F-100 and went to rent a clutch alignment kit. Rent was $8 and purchase was $12. Of course I went with the $12 purchase. That was almost 28 years ago and I haven't used it since.
Old Jan 28, 2011 | 09:25 PM
zunijoe's Avatar
zunijoe
Ford truck history
1973 F-100 360 std sold
1983 F-100 300 std traded for 55 Chevy and $300
1990 F-150 auto 3 speed with o/d 4 wheel drive
1998 Cobra conv. not a truck but hauls ***
Old Jan 28, 2011 | 09:47 PM
Ohio Ford Farm
I had to pull mine on my 91 F250 with tilt a couple times. Never used a hammer to remove the wheel. The puller will pop it right off with a turn of the wrench.
Yes hitting it with a hammer will mush the end of the shaft. Been there done that.
Old Jan 31, 2011 | 11:07 AM
zunijoe's Avatar
zunijoe
I called NAPA and they said they had the lock cylinder for $26 but did not rent or loan tools. I called Advance and they had the lock cylinder for $13 and the removal tool for $20 deposit which I get back when I return the tool (up to 45 days). The removal tool worked great. I appreciate all of the help, but when I got the lock cylinder I found out tht the steering wheel doesn't have to be removed on any Ford products except the older ones without a shroud. Doesn't matter because I don't think the lock cylinder was the problem so the wheel had to come off anyway.
sammie0126
Sep 20, 2021 09:54 PM
Mattyhawk
Aug 5, 2018 10:47 AM
dreamofford
37
Aug 26, 2017 04:22 PM
Walleye Hunter
Apr 15, 2016 07:16 PM
1983F1503004x4
Mar 5, 2013 11:57 AM
